Ir para o conteúdo principal
Sony Vaio VPCW211AX RAM Replacement
O que você precisa
    1. Sony Vaio VPCW211AX RAM  Replacement, Keyboard: passo 1, imagem 1 %32
      • Start with the laptop face up on a flat surface.
      Pergunte ao FixBot
      Comentar
    2. Sony Vaio VPCW211AX RAM  Replacement: passo 2, imagem 1 %32
      • Open the laptop with the keyboard facing you.
      Pergunte ao FixBot
      Comentar
    3. Sony Vaio VPCW211AX RAM  Replacement: passo 3, imagem 1 %32 Sony Vaio VPCW211AX RAM  Replacement: passo 3, imagem 2 %32
      • Use a plastic opening tool to pry up the keyboard. Start at the end closest to the screen.
      • Be careful around the edges; work your way around the keyboard until all of it is detached.
      • There will be a ribbon cable attached to the bottom of the keyboard. Be sure not to rip the cable when lifting the keyboard from the laptop frame.
      Pergunte ao FixBot
      Comentar
    4. Sony Vaio VPCW211AX RAM  Replacement: passo 4, imagem 1 %32 Sony Vaio VPCW211AX RAM  Replacement: passo 4, imagem 2 %32
      • Carefully detach the ribbon from the base of the computer with your hands.
      • Remove the keyboard.
      Pergunte ao FixBot
      Comentar
    1. Sony Vaio VPCW211AX RAM  Replacement, RAM: passo 5, imagem 1 %32
      • Use a Philips #0 screwdriver to remove the 7 top case screws.
      Pergunte ao FixBot
      Comentar
    2. Sony Vaio VPCW211AX RAM  Replacement: passo 6, imagem 1 %32
      • Using a metal spudger, pry open at the seams.
      • Open the gray top of the laptop from the base black portion.
      • Slide the spudger along the seam, and then carefully open the top.
      Pergunte ao FixBot
      Comentar
    3. Sony Vaio VPCW211AX RAM  Replacement: passo 7, imagem 1 %32 Sony Vaio VPCW211AX RAM  Replacement: passo 7, imagem 2 %32
      • Open the top carefully without disconnecting the two parts.
      • Be mindful and careful of the ribbon cable attaching the two parts together.
      Pergunte ao FixBot
      Comentar
    4. Sony Vaio VPCW211AX RAM  Replacement: passo 8, imagem 1 %32 Sony Vaio VPCW211AX RAM  Replacement: passo 8, imagem 2 %32
      • Using your fingers, pry apart the two side metal pieces that hold the part in place as shown on the picture.
      Pergunte ao FixBot
      Comentar
    5. Sony Vaio VPCW211AX RAM  Replacement: passo 9, imagem 1 %32
      • After that step, the RAM should pop up on its own as shown in the picture.
      Pergunte ao FixBot
      Comentar
    6. Sony Vaio VPCW211AX RAM  Replacement: passo 10, imagem 1 %32 Sony Vaio VPCW211AX RAM  Replacement: passo 10, imagem 2 %32
      • Carefully press the sides near the right edge of the part and remove it from it's base.
      Pergunte ao FixBot
      Comentar
Conclusão
1Comentário do guia
I have a 21212L and you have to remove the screws under the flap to remove the keyboard firstm you also do not have to remove the top assembly at all.
Samuel Gottschall - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 17
Últimos 30 dias: 44
Ao todo: 1,234
