Ir para o conteúdo principal
Sony Vaio VGN-SZ120P screen Replacement
O que você precisa
  1. Sony Vaio VGN-SZ120P screen Replacement, Battery: passo 1, imagem 1 %32
    • Set the computer display-side down.
    • Unlock the battery by sliding the port-side latch to the 'unlock' position.
  2. Sony Vaio VGN-SZ120P screen Replacement: passo 2, imagem 1 %32
    • On the opposite side of the battery, press the release latch and slide the battery away from the main body to remove.
  3. Sony Vaio VGN-SZ120P screen Replacement, Keyboard: passo 3, imagem 1 %32
    • Ignore the removal of the heat sink and memory panels as depicted. They do not need to be removed for the completion of this guide.
    • Remove the Torx security screw near the center of the battery-side edge.
  4. Sony Vaio VGN-SZ120P screen Replacement: passo 4, imagem 1 %32 Sony Vaio VGN-SZ120P screen Replacement: passo 4, imagem 2 %32
    • Press the tabs on each side of the display-side of the keyboard with the flat edge of a spudger.
    • Pull the keyboard toward the mouse pad and gently lift up.
  5. Sony Vaio VGN-SZ120P screen Replacement: passo 5, imagem 1 %32 Sony Vaio VGN-SZ120P screen Replacement: passo 5, imagem 2 %32
    • The keyboard is still attached by ribbon cable, don't try to remove the keyboard entirely yet.
    • Disconnect the ribbon cable by pressing the tabs on either side of the connector. Pull the cable out parallel to the connector.
    • Remove the keyboard.
  6. Sony Vaio VGN-SZ120P screen Replacement, Mouse Assembly: passo 6, imagem 1 %32
    • Turn the laptop upside down.
    • Remove the three screws from the front mouse panel located on the bottom of the laptop.
    • Carefully flip the laptop back over. Remove three more screws from the top securing the panel. A ribbon cable will still be attached to the panel when you remove it.
  7. Sony Vaio VGN-SZ120P screen Replacement: passo 7, imagem 1 %32 Sony Vaio VGN-SZ120P screen Replacement: passo 7, imagem 2 %32
    • Lift the mouse assembly just enough to access the connecting ribbon cable.
    • Lift the ribbon cable lock to remove the cable.
    • Carefully remove the mouse panel assembly and set aside.
  8. Sony Vaio VGN-SZ120P screen Replacement, Speaker Assembly: passo 8, imagem 1 %32 Sony Vaio VGN-SZ120P screen Replacement, Speaker Assembly: passo 8, imagem 2 %32 Sony Vaio VGN-SZ120P screen Replacement, Speaker Assembly: passo 8, imagem 3 %32
    • Remove the four screws from the underside of the computer. These screws are located underneath where the battery sits and secure the top keyboard panel.
    • To remove the panel below the screen, press up on the two tabs holding the panel in and lift up. The panel should pop off.
    • Before proceeding, remove all black tape holding down wires and other cabling.
  9. Sony Vaio VGN-SZ120P screen Replacement: passo 9, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Pop off the antenna using a pair of tweezers.
  10. Sony Vaio VGN-SZ120P screen Replacement: passo 10, imagem 1 %32
    • Remove the seven philips screws holding the speaker assembly in place.
    • Before removing the assembly, disconnect the ribbon cable located at the top left corner of the assembly.
    • The speaker assembly will come off with the display assembly.
  11. Sony Vaio VGN-SZ120P screen Replacement, screen: passo 11, imagem 1 %32 Sony Vaio VGN-SZ120P screen Replacement, screen: passo 11, imagem 2 %32
    • Caution: Be careful of snags when pulling up assembly and speakers.
    • To remove the VGA cable, lift up on the metal bracket and gently lift the connector off the logic board.
    • To remove the webcam cable, lift up the connector from the logic board gently.
  12. Sony Vaio VGN-SZ120P screen Replacement: passo 12, imagem 1 %32 Sony Vaio VGN-SZ120P screen Replacement: passo 12, imagem 2 %32 Sony Vaio VGN-SZ120P screen Replacement: passo 12, imagem 3 %32
    • Unscrew the four securing screws, two on each side of the LCD.
    • Carefully remove the LCD. The speaker, bluetooth, and webcam assembly will come up with the display assembly.
    • Caution: Be careful of snags when pulling up display and speaker assemblies.
Conclusão
Colin Glaves
Membro desde: 04/09/10
464 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 25-89, Amido Spring 2010 Membro de Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Membros
Autoria de 61 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 21
Ao todo: 7,813
