Introdução
This guide will show you how to remove the keyboard from your Sony Vaio VGN-FS640 laptop.
O que você precisa
With the bottom of the laptop facing up, locate the RAM cover.
The RAM is covered by the panel with four columns of vents.
Locate the screw (Length: 4.8 mm) holding down the panel, which is near the edge of the laptop. Unscrew it with your phillips #0 screwdriver.
Locate and remove the screw (Length: 7.7mm) for the hard drive cover.
Slide the cover until it is free from the laptop case.
Lift the cover to remove.
Locate the screws highlighted here. There are 16 total.
Using a Phillips #0 screwdriver, remove the screws (Length: 6.8mm) and place them on a tray for later use.
After the back cover is removed, lay the laptop on a flat surface, with the bottom facing up.
On each side of the white plastic connector, there is a tiny black tab that locks the ribbon into place.
Use the sharp edge of a spudger to slide the black tabs away from from the white plastic connector.
Once the tabs have been extended away from the connector, the ribbon can be removed from the keyboard.
The keyboard is now completely disconnected from the laptop.
3 outras pessoas executaram este guia.
1Comentário do guia
You only need to remove the 2 screws in the battery compartment to complete this replacement. The student may be brilliant but he sure enjoys doing unnecessarily long, overly complex, and potentially damaging tasks. ;-)
