Ir para o conteúdo principal
Sony Vaio SVT131A11L Battery Replacement
O que você precisa
  1. Sony Vaio SVT131A11L  Battery Replacement, Battery: passo 1, imagem 1 %32 Sony Vaio SVT131A11L  Battery Replacement, Battery: passo 1, imagem 2 %32 Sony Vaio SVT131A11L  Battery Replacement, Battery: passo 1, imagem 3 %32
    • Carefully grab the edges of the laptop and flip it over to reveal the back panel.
    • The battery is located on the lower half of the back panel, and contains three 10mm flat-head screws.
    • Unscrew the three 10mm flat-head screws using a flat-head screw driver.
    • Lift the battery from the lip closest to the middle screw to remove the battery entirely.
    Pergunte ao FixBot
    Comentar
Conclusão
Benjamin
Membro desde: 10/18/17
675 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team S4-G5, Julie Fall 2017 Membro de UMass Dartmouth, Team S4-G5, Julie Fall 2017
UMASSD-JULIE-F17S4G5
3 Membros
Autoria de 10 guias
7Comentários do guia
Hello,
Where can I buy a replacement battery? The link for amazon does not work.
kristina1152003 - Responder Compartilhar
I bought it from amazon, look for bps30 and youll find it.
rg.paulinha - Responder Compartilhar
It says battery not detected, what can I do?
My 3rd party battery is not recognized as well. Any tips for me?
Shivakumar Sundaram - Responder Compartilhar
Hi, I need a body pannel for Sony laptop model number:SVT131A11L. Already used piece also I will take if it is good. Please help me.
Sriram Gokani - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 15
Últimos 30 dias: 45
Ao todo: 4,281
