Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Using a #1 Phillips screwdriver, remove the two 5mm screws as directed.
Slide off the back cover.
Remove the four 3mm screws using the Phillips #1 screwdriver.
Lift out the hard drive and unplug the orange ribbon wire.
To loosen the keyboard, remove the twenty 5mm screws using the Phillips #1 screwdriver.
Flip the device over and open it up.
Using a plastic opening tool and opening picks, pry off the keyboard from the bottom cover. Start from one of the corners of the device and work your way around.
Remove the keyboard from the bottom cover and place it down as demonstrated.
Carefully pull the plastic tab and remove the ribbon wire.
Slightly pull up the black tape covering the disk drive's ribbon wire.
Pull up the blue plastic strip attached to the ribbon wire and remove the ribbon wire from the port.
Detach the ribbon wire from the fan so the disk reader can be removed.
Remove the two 3mm screws using the Phillips #1 screwdriver.
Take out the black plastic covering.
Remove the disk reader.
