Ir para o conteúdo principal
Sony Vaio SVE111B11L Screen Replacement
O que você precisa
    1. Sony Vaio SVE111B11L  Screen Replacement, Battery: passo 1, imagem 1 %32 Sony Vaio SVE111B11L  Screen Replacement, Battery: passo 1, imagem 2 %32
      • Remove the charging adaptor. Some charge may still be in the battery or computer. DO NOT touch connectors or copper yellow connector.
      • Locate the battery on the bottom of the computer.
      • Flip the computer so that the battery faces you.
      Pergunte ao FixBot
      Comentar
    2. Sony Vaio SVE111B11L  Screen Replacement: passo 2, imagem 1 %32
      • Locate the two latches with the words “lock” and “release” on them.
      Pergunte ao FixBot
      Comentar
    3. Sony Vaio SVE111B11L  Screen Replacement: passo 3, imagem 1 %32
      • Push the latches towards each other and lift the battery to remove it.
      Pergunte ao FixBot
      Comentar
    1. Sony Vaio SVE111B11L  Screen Replacement, Keyboard Assembly: passo 4, imagem 1 %32
      • Remove the memory door on the bottom of the computer to access the screw for the keyboard.
      • The screws for the memory door do not come out.
      Pergunte ao FixBot
      Comentar
    2. Sony Vaio SVE111B11L  Screen Replacement: passo 5, imagem 1 %32
      • Remove the 6.7 mm screw that holds the keyboard assembly in place.
      Pergunte ao FixBot
      Comentar
    3. Sony Vaio SVE111B11L  Screen Replacement: passo 6, imagem 1 %32
      • Be careful not to break the keyboard wire connection.
      • Slide the wires out, away from the solder connections.
      • Flip the computer over and open it.
      Pergunte ao FixBot
      Comentar
    4. Sony Vaio SVE111B11L  Screen Replacement: passo 7, imagem 1 %32 Sony Vaio SVE111B11L  Screen Replacement: passo 7, imagem 2 %32 Sony Vaio SVE111B11L  Screen Replacement: passo 7, imagem 3 %32
      • Gently pry the keyboard assembly from the screen side, using an opening tool. You will need to lift the keyboard about two inches.
      • Using an opening tool, gently pull out and slightly up on the connector clip.
      • Gently lift the keyboard assembly up and out.
      Pergunte ao FixBot
      Comentar
    1. Sony Vaio SVE111B11L  Screen Replacement, Motherboard: passo 8, imagem 1 %32
      • Remove charging adaptor. Some charge may still be in the battery or computer.
      • DO NOT touch connectors or copper yellow connector.
      • Take the covers on the bottom of the laptop off.
      Pergunte ao FixBot
      Comentar
    2. Sony Vaio SVE111B11L  Screen Replacement: passo 9, imagem 1 %32
      • Locate and remove the screws holding the motherboard down.
      • Screws: L 4.6mm X D 1.85mm
      Pergunte ao FixBot
      Comentar
    3. Sony Vaio SVE111B11L  Screen Replacement: passo 10, imagem 1 %32 Sony Vaio SVE111B11L  Screen Replacement: passo 10, imagem 2 %32 Sony Vaio SVE111B11L  Screen Replacement: passo 10, imagem 3 %32
      • Locate the wires and connectors and remove them from the motherboard.
      Pergunte ao FixBot
      Comentar
    4. Sony Vaio SVE111B11L  Screen Replacement: passo 11, imagem 1 %32 Sony Vaio SVE111B11L  Screen Replacement: passo 11, imagem 2 %32
      • Lift the mother board out and safely put it to the side.
      Pergunte ao FixBot
      Comentar
    1. Sony Vaio SVE111B11L  Screen Replacement, Screen: passo 12, imagem 1 %32 Sony Vaio SVE111B11L  Screen Replacement, Screen: passo 12, imagem 2 %32
      • Remove charging adaptor and battery. Some charge may still be in the battery or computer.
      • Locate screws. L 3.35mm X D 1.8mm
      • Remove Screws.
      • Lay the screen on a hard flat surface.
      • Remove hinges and wires for ease of removal.
      Pergunte ao FixBot
      Comentar
    2. Sony Vaio SVE111B11L  Screen Replacement: passo 13, imagem 1 %32
      • Gently remove the screen cover.
      • Be careful of the camera at the top of the screen.
      • Be careful of the seal tape between the cover and the screen.
      Pergunte ao FixBot
      Comentar
    3. Sony Vaio SVE111B11L  Screen Replacement: passo 14, imagem 1 %32 Sony Vaio SVE111B11L  Screen Replacement: passo 14, imagem 2 %32 Sony Vaio SVE111B11L  Screen Replacement: passo 14, imagem 3 %32
      • Locate the wires and connectors.
      • Unplug the wires from the connectors.
      • Be careful of the yellow tape around the connection.
      Pergunte ao FixBot
      Comentar
    4. Sony Vaio SVE111B11L  Screen Replacement: passo 15, imagem 1 %32 Sony Vaio SVE111B11L  Screen Replacement: passo 15, imagem 2 %32
      • Gently lift the screen assembly up and out.
      Pergunte ao FixBot
      Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 29
Ao todo: 1,743
