Introdução
If your keys appear to be broken, replacing the keyboard may be necessary.
To make sure the problem is with the keyboard, follow the troubleshooting guide.
When buying a new keyboard make sure it is compatible with PCG-F420.
CAUTION: Static electricity in your body can ruin your computer. Use an anti-static wristband.
Before you begin the repair, turn off your laptop and unplug the charger.
O que você precisa
The battery is located on the left side of the laptop, as shown by the red circle.
Make sure the laptop is disconnected and turned completely off.
Use your Philips #00 screwdriver to unscrew the small screw counterclockwise. This screw is for the audio/visual jacks on the left side of the laptop.
Uma outra pessoa concluiu este guia.
