Ir para o conteúdo principal
Sony Vaio PCG-4G1L Keyboard Replacement
O que você precisa
    1. Sony Vaio PCG-4G1L Keyboard Replacement, Battery: passo 1, imagem 1 %32
      • Turn off the computer and disconnect the charging cable.
      • Failing to unplug the cable can result in electric shock.
      Pergunte ao FixBot
      Comentar
    2. Sony Vaio PCG-4G1L Keyboard Replacement: passo 2, imagem 1 %32 Sony Vaio PCG-4G1L Keyboard Replacement: passo 2, imagem 2 %32
      • Slide battery release toggle switch towards the "RELEASE" print.
      Pergunte ao FixBot
      Comentar
    3. Sony Vaio PCG-4G1L Keyboard Replacement: passo 3, imagem 1 %32 Sony Vaio PCG-4G1L Keyboard Replacement: passo 3, imagem 2 %32 Sony Vaio PCG-4G1L Keyboard Replacement: passo 3, imagem 3 %32
      • Apply pressure with your thumb on the grip.
      • Pull the battery out while simultaneously holding the battery release toggle switch in the release position.
      Pergunte ao FixBot
      Comentar
    1. Sony Vaio PCG-4G1L Keyboard Replacement, Keyboard: passo 4, imagem 1 %32 Sony Vaio PCG-4G1L Keyboard Replacement, Keyboard: passo 4, imagem 2 %32
      • Remove one 5 mm Phillips #1 pan head screw, in the middle of the laptop, using a Bit Driver with Phillips PH1 bit.
      Pergunte ao FixBot
      Comentar
    2. Sony Vaio PCG-4G1L Keyboard Replacement: passo 5, imagem 1 %32 Sony Vaio PCG-4G1L Keyboard Replacement: passo 5, imagem 2 %32
      • Be sure to pry the plastic opening tool under the keyboard, rather than under the keys. Otherwise, some keys could get harmed.
      • While using a plastic opening tool, carefully lift the keyboard by inserting the tool under the edge.
      Pergunte ao FixBot
      Comentar
    3. Sony Vaio PCG-4G1L Keyboard Replacement: passo 6, imagem 1 %32 Sony Vaio PCG-4G1L Keyboard Replacement: passo 6, imagem 2 %32 Sony Vaio PCG-4G1L Keyboard Replacement: passo 6, imagem 3 %32
      • Do not pull the keyboard too far away, as a ribbon cable is still attached. Failing to do so can cause damage to the ribbon cable or the connector.
      • Use the plastic opening tool to release the clamp.
      • Using slight pressure, remove the ribbon cable with your fingers.
      Pergunte ao FixBot
      Comentar
Conclusão
Cole Collins
Membro desde: 10/04/16
211 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 2-3, Cagle Fall 2016 Membro de USF Tampa, Team 2-3, Cagle Fall 2016
USFT-CAGLE-F16S2G3
5 Membros
Autoria de 18 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 44
Ao todo: 1,305
