Ir para o conteúdo principal
Sony Vaio PCG-4G1L Hard Drive Replacement
O que você precisa
    1. Sony Vaio PCG-4G1L Hard Drive  Replacement, Battery: passo 1, imagem 1 %32
      • Turn off the computer and disconnect the charging cable.
      • Failing to unplug the cable can result in electric shock.
      Pergunte ao FixBot
      Comentar
    2. Sony Vaio PCG-4G1L Hard Drive  Replacement: passo 2, imagem 1 %32 Sony Vaio PCG-4G1L Hard Drive  Replacement: passo 2, imagem 2 %32
      • Slide battery release toggle switch towards the "RELEASE" print.
      Pergunte ao FixBot
      Comentar
    3. Sony Vaio PCG-4G1L Hard Drive  Replacement: passo 3, imagem 1 %32 Sony Vaio PCG-4G1L Hard Drive  Replacement: passo 3, imagem 2 %32 Sony Vaio PCG-4G1L Hard Drive  Replacement: passo 3, imagem 3 %32
      • Apply pressure with your thumb on the grip.
      • Pull the battery out while simultaneously holding the battery release toggle switch in the release position.
      Pergunte ao FixBot
      Comentar
    1. Sony Vaio PCG-4G1L Hard Drive  Replacement, Keyboard: passo 4, imagem 1 %32 Sony Vaio PCG-4G1L Hard Drive  Replacement, Keyboard: passo 4, imagem 2 %32
      • Remove one 5 mm Phillips #1 pan head screw, in the middle of the laptop, using a Bit Driver with Phillips PH1 bit.
      Pergunte ao FixBot
      Comentar
    2. Sony Vaio PCG-4G1L Hard Drive  Replacement: passo 5, imagem 1 %32 Sony Vaio PCG-4G1L Hard Drive  Replacement: passo 5, imagem 2 %32
      • Be sure to pry the plastic opening tool under the keyboard, rather than under the keys. Otherwise, some keys could get harmed.
      • While using a plastic opening tool, carefully lift the keyboard by inserting the tool under the edge.
      Pergunte ao FixBot
      Comentar
    3. Sony Vaio PCG-4G1L Hard Drive  Replacement: passo 6, imagem 1 %32 Sony Vaio PCG-4G1L Hard Drive  Replacement: passo 6, imagem 2 %32 Sony Vaio PCG-4G1L Hard Drive  Replacement: passo 6, imagem 3 %32
      • Do not pull the keyboard too far away, as a ribbon cable is still attached. Failing to do so can cause damage to the ribbon cable or the connector.
      • Use the plastic opening tool to release the clamp.
      • Using slight pressure, remove the ribbon cable with your fingers.
      Pergunte ao FixBot
      Comentar
    1. Sony Vaio PCG-4G1L Hard Drive  Replacement, Network Antenna: passo 7, imagem 1 %32
      • Swivel the Network Antenna up so that it points upward.
      Pergunte ao FixBot
      Comentar
    2. Sony Vaio PCG-4G1L Hard Drive  Replacement: passo 8, imagem 1 %32 Sony Vaio PCG-4G1L Hard Drive  Replacement: passo 8, imagem 2 %32
      • Pinch thumb and index finger at the Network Antenna's base.
      • Make sure not to bend the Network Antenna. Failing to do so can cause damage to the antenna.
      • Pull the Network Antenna off.
      Pergunte ao FixBot
      Comentar
    1. Sony Vaio PCG-4G1L Hard Drive  Replacement, Plastic Casing: passo 9, imagem 1 %32 Sony Vaio PCG-4G1L Hard Drive  Replacement, Plastic Casing: passo 9, imagem 2 %32
      • Remove seven 5 mm Phillips #1 pan head screws with a Bit Driver, using a Phillips PH1 bit.
      Pergunte ao FixBot
      Comentar
    2. Sony Vaio PCG-4G1L Hard Drive  Replacement: passo 10, imagem 1 %32 Sony Vaio PCG-4G1L Hard Drive  Replacement: passo 10, imagem 2 %32
      • Remove one 7 mm Phillips #1 Pan Head Screw by using a Bit Driver with Phillips PH1 bit.
      Pergunte ao FixBot
      Comentar
    3. Sony Vaio PCG-4G1L Hard Drive  Replacement: passo 11, imagem 1 %32 Sony Vaio PCG-4G1L Hard Drive  Replacement: passo 11, imagem 2 %32
      Ferramenta utilizada neste passo:
      • Disconnect the cable by using the precision tweezers.
      • Slowly pry out the ribbon cable by using the plastic opening tool.
      Pergunte ao FixBot
      Comentar
    4. Sony Vaio PCG-4G1L Hard Drive  Replacement: passo 12, imagem 1 %32
      • Do not pull the plastic cover too far away, as a ribbon cable is still attached. Failing to do so can cause damage to ribbon cable or the connector.
      • Remove the plastic cover by inserting the plastic opening tool around the edge.
      Pergunte ao FixBot
      Comentar
    5. Sony Vaio PCG-4G1L Hard Drive  Replacement: passo 13, imagem 1 %32 Sony Vaio PCG-4G1L Hard Drive  Replacement: passo 13, imagem 2 %32
      • Disconnect the ribbon cable by pulling straight up with your fingers.
      Pergunte ao FixBot
      Comentar
    1. Sony Vaio PCG-4G1L Hard Drive  Replacement, Hard Drive: passo 14, imagem 1 %32 Sony Vaio PCG-4G1L Hard Drive  Replacement, Hard Drive: passo 14, imagem 2 %32
      • Remove three 5 mm Phillips #0 flat head screws using a Bit Driver with a Phillips PH000 bit.
      • Remove the bracket with your fingers.
      Pergunte ao FixBot
      Comentar
    2. Sony Vaio PCG-4G1L Hard Drive  Replacement: passo 15, imagem 1 %32 Sony Vaio PCG-4G1L Hard Drive  Replacement: passo 15, imagem 2 %32 Sony Vaio PCG-4G1L Hard Drive  Replacement: passo 15, imagem 3 %32
      • Using the plastic opening tool, pry out the side of the hard drive.
      • The hard drive should easily disconnect from the connector.
      • Slide the hard drive out, towards the left side of the case, while your fingers apply pressure to the ribbon cable.
      Pergunte ao FixBot
      Comentar
Conclusão
3 outras pessoas executaram este guia.
Diego Fabiano
Membro desde: 10/04/16
195 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 2-3, Cagle Fall 2016 Membro de USF Tampa, Team 2-3, Cagle Fall 2016
USFT-CAGLE-F16S2G3
5 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 22
Últimos 30 dias: 90
Ao todo: 12,356
