Ir para o conteúdo principal
Sony Vaio PCG-4121GL Keyboard Replacement
O que você precisa
    1. Sony Vaio PCG-4121GL Keyboard Replacement, Battery: passo 1, imagem 1 %32 Sony Vaio PCG-4121GL Keyboard Replacement, Battery: passo 1, imagem 2 %32
      • Remove the two 3mm Phillips #0 screws on the bottom of the computer that secure the plastic backing.
      Pergunte ao FixBot
      Comentar
    2. Sony Vaio PCG-4121GL Keyboard Replacement: passo 2, imagem 1 %32 Sony Vaio PCG-4121GL Keyboard Replacement: passo 2, imagem 2 %32 Sony Vaio PCG-4121GL Keyboard Replacement: passo 2, imagem 3 %32
      • Pull the bottom plate towards yourself until it unhinges fully.
      • Once the plate is free from the backing remove it completely.
      Pergunte ao FixBot
      Comentar
    3. Sony Vaio PCG-4121GL Keyboard Replacement: passo 3, imagem 1 %32
      • Look for the blue tab that is located to the bottom left of the battery.
      Pergunte ao FixBot
      Comentar
    4. Sony Vaio PCG-4121GL Keyboard Replacement: passo 4, imagem 1 %32 Sony Vaio PCG-4121GL Keyboard Replacement: passo 4, imagem 2 %32 Sony Vaio PCG-4121GL Keyboard Replacement: passo 4, imagem 3 %32
      • Pull the blue tab towards yourself until you hear a click.
      • Once the blue tab is released, pull up on the battery.
      • Once the battery can move freely, take it out completely.
      • It may be helpful to have a spudger to make it easier to release the blue tab.
      Pergunte ao FixBot
      Comentar
    1. Sony Vaio PCG-4121GL Keyboard Replacement, Keyboard: passo 5, imagem 1 %32 Sony Vaio PCG-4121GL Keyboard Replacement, Keyboard: passo 5, imagem 2 %32
      • Remove seven 3mm Phillips #0 screws from the bottom of the computer.
      • Remove eight 5mm Phillips #0 screws.
      Pergunte ao FixBot
      Comentar
    2. Sony Vaio PCG-4121GL Keyboard Replacement: passo 6, imagem 1 %32 Sony Vaio PCG-4121GL Keyboard Replacement: passo 6, imagem 2 %32 Sony Vaio PCG-4121GL Keyboard Replacement: passo 6, imagem 3 %32
      • Carefully remove the disk drive from its compartment.
      Pergunte ao FixBot
      Comentar
    3. Sony Vaio PCG-4121GL Keyboard Replacement: passo 7, imagem 1 %32 Sony Vaio PCG-4121GL Keyboard Replacement: passo 7, imagem 2 %32
      • Remove the three 2mm Phillips #00 screws located on the top right edge.
      Pergunte ao FixBot
      Comentar
    4. Sony Vaio PCG-4121GL Keyboard Replacement: passo 8, imagem 1 %32 Sony Vaio PCG-4121GL Keyboard Replacement: passo 8, imagem 2 %32 Sony Vaio PCG-4121GL Keyboard Replacement: passo 8, imagem 3 %32
      • Gently pull apart the top and bottom plastic bodies.
      • Carefully lift up tabs to detach cable connectors.
      • Slowly detach bottom component to avoid tearing wires/connectors.
      Pergunte ao FixBot
      Comentar
    5. Sony Vaio PCG-4121GL Keyboard Replacement: passo 9, imagem 1 %32 Sony Vaio PCG-4121GL Keyboard Replacement: passo 9, imagem 2 %32 Sony Vaio PCG-4121GL Keyboard Replacement: passo 9, imagem 3 %32
      • Remove the tape strips along the edge of the keyboard.
      • Once the keyboard is disconnected, slowly poke out keys one-by-one.
      • When the keyboard is free to move, remove it completely.
      • The keyboard is held in place with glue, once it is removed it is likely that it will not go back in the same way.
      Pergunte ao FixBot
      Comentar
Conclusão
4 outras pessoas executaram este guia.
Equipe
Cal Poly, Team S2-G2, White Winter 2019 Membro de Cal Poly, Team S2-G2, White Winter 2019
CPSU-WHITE-W19S2G2
4 Membros
Autoria de 10 guias
1Comentário do guia
Im having trouble putting the keyboard cables back
Ishaan Patel - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 39
Ao todo: 2,389
