Ir para o conteúdo principal
Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement
O que você precisa
  1. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement, Back Cover: passo 1, imagem 1 %32 Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement, Back Cover: passo 1, imagem 2 %32
    • Starting with the laptop top-down, locate and remove the twelve 1mm Phillips #0 screws securing the back cover to the main body of the computer.
  2. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement: passo 2, imagem 1 %32 Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement: passo 2, imagem 2 %32
    • Use the Plastic Opening Tools or Metal Spudger to carefully loosen back cover from the body of the computer.
    • Be sure to avoid headphone jack when removing back cover by lifting cover away from computer and up.
  3. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement: passo 3, imagem 1 %32
    • Lift off back cover to access inner components of computer.
  4. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement, Fan: passo 4, imagem 1 %32 Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement, Fan: passo 4, imagem 2 %32
    • Remove the three 1mm Phillips #0 screws surrounding the fan.
    • Loosen the three 1mm Phillips #0 screws. These screws will stay captive to the heatsink.
  5. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement: passo 5, imagem 1 %32 Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement: passo 5, imagem 2 %32 Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement: passo 5, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use tweezers to carefully unplug the fan connector.
  6. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement, Remove the Fan: passo 6, imagem 1 %32 Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement, Remove the Fan: passo 6, imagem 2 %32
    • Use the Plastic Opening Tool to gently remove the heat sink and fan assembly from the computer.
    • Important: Follow the How to Apply Thermal Paste guide to replace the thermal paste before reassembling your device.
Conclusão
4 outras pessoas executaram este guia.
Marii
Membro desde: 01/08/15
658 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 21-19, Maness Winter 2015 Membro de Cal Poly, Team 21-19, Maness Winter 2015
CPSU-MANESS-W15S21G19
Membros da 4
Autoria de 12 guias
Um comentário
Could you also maybe do a tutorial on Sony Vaio Fit 13? http://www.laptoppartstore.com/replace--... Any luck figuring out how the fan may be detached and re-attached to the heatsink? Also, I notice a very specific type of taping... where can one procure those?
Abhishek D - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 4,570
