Ir para o conteúdo principal
Sony Vaio Fit 13A Charger Port Replacement
O que você precisa
  1. Sony Vaio Fit 13A Charger Port Replacement, Back Cover: passo 1, imagem 1 %32 Sony Vaio Fit 13A Charger Port Replacement, Back Cover: passo 1, imagem 2 %32
    • Starting with the laptop top-down, locate and remove the twelve 1mm Phillips #0 screws securing the back cover to the main body of the computer.
  2. Sony Vaio Fit 13A Charger Port Replacement: passo 2, imagem 1 %32 Sony Vaio Fit 13A Charger Port Replacement: passo 2, imagem 2 %32
    • Use the Plastic Opening Tools or Metal Spudger to carefully loosen back cover from the body of the computer.
    • Be sure to avoid headphone jack when removing back cover by lifting cover away from computer and up.
  3. Sony Vaio Fit 13A Charger Port Replacement: passo 3, imagem 1 %32
    • Lift off back cover to access inner components of computer.
  4. Sony Vaio Fit 13A Charger Port Replacement, Fan: passo 4, imagem 1 %32 Sony Vaio Fit 13A Charger Port Replacement, Fan: passo 4, imagem 2 %32
    • Remove the three 1mm Phillips #0 screws surrounding the fan.
    • Loosen the three 1mm Phillips #0 screws. These screws will stay captive to the heatsink.
  5. Sony Vaio Fit 13A Charger Port Replacement: passo 5, imagem 1 %32 Sony Vaio Fit 13A Charger Port Replacement: passo 5, imagem 2 %32 Sony Vaio Fit 13A Charger Port Replacement: passo 5, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use tweezers to carefully unplug the fan connector.
  6. Sony Vaio Fit 13A Charger Port Replacement, Remove the Fan: passo 6, imagem 1 %32 Sony Vaio Fit 13A Charger Port Replacement, Remove the Fan: passo 6, imagem 2 %32
    • Use the Plastic Opening Tool to gently remove the heat sink and fan assembly from the computer.
    • Important: Follow the How to Apply Thermal Paste guide to replace the thermal paste before reassembling your device.
  7. Sony Vaio Fit 13A Charger Port Replacement, Charger Port: passo 7, imagem 1 %32 Sony Vaio Fit 13A Charger Port Replacement, Charger Port: passo 7, imagem 2 %32 Sony Vaio Fit 13A Charger Port Replacement, Charger Port: passo 7, imagem 3 %32
    • Remove 1mm screw using a Phillips Head #0 screwdriver.
    • Remove two 3mm screws using a Phillips Head #1 screwdriver.
  8. Sony Vaio Fit 13A Charger Port Replacement: passo 8, imagem 1 %32
    Comprar
    • Use tweezers to carefully remove the charger port cover.
  9. Sony Vaio Fit 13A Charger Port Replacement, Unplug the Port: passo 9, imagem 1 %32 Sony Vaio Fit 13A Charger Port Replacement, Unplug the Port: passo 9, imagem 2 %32
    • Gently unplug charger port from motherboard using tweezers.
Conclusão
6 outras pessoas executaram este guia.
Marii
Membro desde: 01/08/15
658 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 21-19, Maness Winter 2015 Membro de Cal Poly, Team 21-19, Maness Winter 2015
CPSU-MANESS-W15S21G19
Membros da 4
Autoria de 12 guias
5 comentários
Excellent instructions, thank you. Now all I need to do is overcome fear, buy some tools and magnifiers, knock on wood and go for it. But I think I'll wait until I can no longer find the sweet spot.
rkotomori - Responder
Where can I buy the charge port?
patrickchughes - Responder
Hi Patrick
this is the same question I have. Did you managed to find one in the meantime ?
Or does anaybody know where to buy one ?
thanx for any help !
cheers
B
Ben - Responder
Don't even bother it will just fail again in a few weeks
I am going to try and redesign it
I already replaced mine and it just failed again
Not even a month later and it was very expensive and nearly impossible to find ,the design is faulty Sony should be sued for releasing this dangerous product
I have to hold it on the "sweet spot" the entire time I am using the computer and constantly reposition it
And it gets 🔥 HOT
Hot enough to burn my fingers
!#^& poor design and it never should have been released like this someone should have realized this this POS is a house fire waiting to happen
anthony rossetti - Responder
I misplaced the old one I took out but I plan on finding it and altering it to include a normal barrel jack instead
Or designing and 3D printing a housing for barrel jack and using the connector that plugs into the motherboard from the old one for the redesigned one
The changing the end on the charger as well ,since I already bought a couple of those before I realized it was the port ,the only solution would be to redesign it to be like normal barrel jack because it will just keep on failing
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 17
Duração total: 4,096
