Ir para o conteúdo principal
Sony VAIO VPC-EB33FM RAM Replacement
O que você precisa
  1. Sony VAIO VPC-EB33FM RAM Replacement, Battery: passo 1, imagem 1 %32 Sony VAIO VPC-EB33FM RAM Replacement, Battery: passo 1, imagem 2 %32
    • Power down the laptop by pressing the power button.
    • Turn the laptop onto its backside.
    Pergunte ao FixBot
    Comentar
  2. Sony VAIO VPC-EB33FM RAM Replacement: passo 2, imagem 1 %32
    • To release the battery, hold both the release button and the unlock button at the same time.
    Pergunte ao FixBot
    Comentar
  3. Sony VAIO VPC-EB33FM RAM Replacement: passo 3, imagem 1 %32 Sony VAIO VPC-EB33FM RAM Replacement: passo 3, imagem 2 %32
    • Remove the battery out from the notch while continuing to hold the release button.
    Pergunte ao FixBot
    Comentar
  4. Sony VAIO VPC-EB33FM RAM Replacement, RAM: passo 4, imagem 1 %32 Sony VAIO VPC-EB33FM RAM Replacement, RAM: passo 4, imagem 2 %32 Sony VAIO VPC-EB33FM RAM Replacement, RAM: passo 4, imagem 3 %32
    • Remove the one screw with a Phillips #00 screwdriver.
    • The screw cannot be removed from the RAM casing cover.
    Pergunte ao FixBot
    Comentar
  5. Sony VAIO VPC-EB33FM RAM Replacement: passo 5, imagem 1 %32 Sony VAIO VPC-EB33FM RAM Replacement: passo 5, imagem 2 %32
    • Pull the two retaining arms away from the center of the RAM chip.
    • The RAM will make a "pop" sound and the RAM stick will rise for ease of handling.
    Pergunte ao FixBot
    Comentar
  6. Sony VAIO VPC-EB33FM RAM Replacement: passo 6, imagem 1 %32 Sony VAIO VPC-EB33FM RAM Replacement: passo 6, imagem 2 %32 Sony VAIO VPC-EB33FM RAM Replacement: passo 6, imagem 3 %32
    • Pull the RAM stick out of its socket.
    • To remove the second stick of RAM, repeat steps six and seven.
    • When installing RAM, make sure sticks are firmly in place or the computer will not register them.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team 18-39, Regan Winter 2013 Membro de Cal Poly, Team 18-39, Regan Winter 2013
CPSU-REGAN-W13S18G39
5 Membros
Autoria de 15 guias
1Comentário do guia
when i press the power button in VAio still black screen with little tick sound,
and one day i just turn it on and leave it for 17 hours and sadnlley it worked but when i tried to restart it it still not working with tick tick tick tick sound !!! any advise !!!?
dorii135 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 17
Últimos 30 dias: 39
Ao todo: 4,745
