Ir para o conteúdo principal
Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Sony VAIO VPC-EB33FM Hard Drive Replacement
O que você precisa
  1. Sony VAIO VPC-EB33FM Hard Drive Replacement, Battery: passo 1, imagem 1 %32 Sony VAIO VPC-EB33FM Hard Drive Replacement, Battery: passo 1, imagem 2 %32
    • Power down the laptop by pressing the power button.
    • Turn the laptop onto its backside.
  2. Sony VAIO VPC-EB33FM Hard Drive Replacement: passo 2, imagem 1 %32
    • To release the battery, hold both the release button and the unlock button at the same time.
  3. Sony VAIO VPC-EB33FM Hard Drive Replacement: passo 3, imagem 1 %32 Sony VAIO VPC-EB33FM Hard Drive Replacement: passo 3, imagem 2 %32
    • Remove the battery out from the notch while continuing to hold the release button.
  4. Sony VAIO VPC-EB33FM Hard Drive Replacement, Hard Drive: passo 4, imagem 1 %32
    • Remove all charge from the laptop by holding down the power button for at least 5 seconds.
  5. Sony VAIO VPC-EB33FM Hard Drive Replacement: passo 5, imagem 1 %32 Sony VAIO VPC-EB33FM Hard Drive Replacement: passo 5, imagem 2 %32
    • Turn laptop onto its backside and locate the hard drive cover panel.
  6. Sony VAIO VPC-EB33FM Hard Drive Replacement: passo 6, imagem 1 %32 Sony VAIO VPC-EB33FM Hard Drive Replacement: passo 6, imagem 2 %32 Sony VAIO VPC-EB33FM Hard Drive Replacement: passo 6, imagem 3 %32
    • Use a Phillips #00 screwdriver to remove the two 7.75-mm cover screws on the bottom corners of the panel.
  7. Sony VAIO VPC-EB33FM Hard Drive Replacement: passo 7, imagem 1 %32 Sony VAIO VPC-EB33FM Hard Drive Replacement: passo 7, imagem 2 %32 Sony VAIO VPC-EB33FM Hard Drive Replacement: passo 7, imagem 3 %32
    • Use a finger/fingernail to grip the notch at the bottom of the panel to lift it off.
    • You may need to use your other hand to safely remove the panel.
    • You can also use a spudger for this step
  8. Sony VAIO VPC-EB33FM Hard Drive Replacement: passo 8, imagem 1 %32
    • The hard drive should now be exposed.
    • Remove the two remaining 7.75-mm screws using the Phillips #00 screwdriver.
  9. Sony VAIO VPC-EB33FM Hard Drive Replacement: passo 9, imagem 1 %32
    • Grab the tab between your thumb and index finger.
    • Hold the hard drive securely in a horizontal position using your other hand.
    • Push the hard drive to the left using the plastic tab to disconnect it from the laptop.
    • To prevent damage of the connection on the hard disk drive or the laptop, perform this task slowly and with care.
  10. Sony VAIO VPC-EB33FM Hard Drive Replacement: passo 10, imagem 1 %32 Sony VAIO VPC-EB33FM Hard Drive Replacement: passo 10, imagem 2 %32
    • While still holding the plastic tab, lift the right side of the hard drive out at a 45º angle.
    • Pull the hard drive out.
  11. Sony VAIO VPC-EB33FM Hard Drive Replacement: passo 11, imagem 1 %32 Sony VAIO VPC-EB33FM Hard Drive Replacement: passo 11, imagem 2 %32
    • If you need to remove the bracket from the hard drive, follow the next few steps:
    • Remove the two 3.67-mm screws from either side of the bracket with a Phillips #00 screwdriver.
    • Lift the bracket off the hard drive.
Conclusão
8 outras pessoas executaram este guia.
Christian
Membro desde: 01/14/13
177 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 18-39, Regan Winter 2013 Membro de Cal Poly, Team 18-39, Regan Winter 2013
CPSU-REGAN-W13S18G39
Membros da 5
Autoria de 15 guias
Um comentário
This is very good step by step instructions guide. Loved it and was able to remove my laptop hd very easily. I created this account only to say thanks to writer. Amazing job !! Thaks ton.
Dinesh - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 21
Duração total: 18,439
