Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Power down the laptop by pressing the power button.
Turn the laptop onto its backside.
To release the battery, hold both the release button and the unlock button at the same time.
Remove the battery out from the notch while continuing to hold the release button.
Use a Phillips #00 screwdriver to remove the two 7.8 mm cover screws on the bottom corners of the panel.
Use a finger/fingernail to grip the notch at the bottom of the panel to lift it off.
Remove the two remaining 7.8 mm screws using the Phillips #00 screwdriver.
Grab the tab between your thumb and index finger.
Hold the hard drive securely in a horizontal position using your other hand.
Push the hard drive to the left using the plastic tab to disconnect it from the laptop.
While still holding the plastic tab, lift the right side of the hard drive out at a 45º angle.
Pull the hard drive out.
If you need to remove the bracket from the hard drive, follow the next few steps:
Remove the two 3.7 mm screws from either side of the bracket with a Phillips #00 screwdriver.
Lift the bracket off the hard drive.
8 outras pessoas executaram este guia.
