Ir para o conteúdo principal
Sony VAIO VPC-EB33FM Hard Drive Replacement
O que você precisa
    1. Sony VAIO VPC-EB33FM Hard Drive Replacement, Battery: passo 1, imagem 1 %32 Sony VAIO VPC-EB33FM Hard Drive Replacement, Battery: passo 1, imagem 2 %32
      • Power down the laptop by pressing the power button.
      • Turn the laptop onto its backside.
      Pergunte ao FixBot
      Comentar
    2. Sony VAIO VPC-EB33FM Hard Drive Replacement: passo 2, imagem 1 %32
      • To release the battery, hold both the release button and the unlock button at the same time.
      Pergunte ao FixBot
      Comentar
    3. Sony VAIO VPC-EB33FM Hard Drive Replacement: passo 3, imagem 1 %32 Sony VAIO VPC-EB33FM Hard Drive Replacement: passo 3, imagem 2 %32
      • Remove the battery out from the notch while continuing to hold the release button.
      Pergunte ao FixBot
      Comentar
    1. Sony VAIO VPC-EB33FM Hard Drive Replacement, Hard Drive: passo 4, imagem 1 %32 Sony VAIO VPC-EB33FM Hard Drive Replacement, Hard Drive: passo 4, imagem 2 %32 Sony VAIO VPC-EB33FM Hard Drive Replacement, Hard Drive: passo 4, imagem 3 %32
      • Use a Phillips #00 screwdriver to remove the two 7.8 mm cover screws on the bottom corners of the panel.
      Pergunte ao FixBot
      Comentar
    2. Sony VAIO VPC-EB33FM Hard Drive Replacement: passo 5, imagem 1 %32 Sony VAIO VPC-EB33FM Hard Drive Replacement: passo 5, imagem 2 %32 Sony VAIO VPC-EB33FM Hard Drive Replacement: passo 5, imagem 3 %32
      • Use a finger/fingernail to grip the notch at the bottom of the panel to lift it off.
      • You may need to use your other hand to safely remove the panel.
      • You can also use a spudger for this step.
      Pergunte ao FixBot
      Comentar
    3. Sony VAIO VPC-EB33FM Hard Drive Replacement: passo 6, imagem 1 %32
      • Remove the two remaining 7.8 mm screws using the Phillips #00 screwdriver.
      Pergunte ao FixBot
      Comentar
    4. Sony VAIO VPC-EB33FM Hard Drive Replacement: passo 7, imagem 1 %32
      • Grab the tab between your thumb and index finger.
      • Hold the hard drive securely in a horizontal position using your other hand.
      • Push the hard drive to the left using the plastic tab to disconnect it from the laptop.
      • To prevent damage of the connection on the hard disk drive or the laptop, perform this task slowly and with care.
      Pergunte ao FixBot
      Comentar
    5. Sony VAIO VPC-EB33FM Hard Drive Replacement: passo 8, imagem 1 %32 Sony VAIO VPC-EB33FM Hard Drive Replacement: passo 8, imagem 2 %32
      • While still holding the plastic tab, lift the right side of the hard drive out at a 45º angle.
      • Pull the hard drive out.
      Pergunte ao FixBot
      Comentar
    6. Sony VAIO VPC-EB33FM Hard Drive Replacement: passo 9, imagem 1 %32 Sony VAIO VPC-EB33FM Hard Drive Replacement: passo 9, imagem 2 %32
      • If you need to remove the bracket from the hard drive, follow the next few steps:
      • Remove the two 3.7 mm screws from either side of the bracket with a Phillips #00 screwdriver.
      • Lift the bracket off the hard drive.
      Pergunte ao FixBot
      Comentar
Conclusão
9 outras pessoas executaram este guia.
Christian
Membro desde: 01/14/13
195 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 18-39, Regan Winter 2013 Membro de Cal Poly, Team 18-39, Regan Winter 2013
CPSU-REGAN-W13S18G39
5 Membros
Autoria de 42 guias
1Comentário do guia
This is very good step by step instructions guide. Loved it and was able to remove my laptop hd very easily. I created this account only to say thanks to writer. Amazing job !! Thaks ton.
Dinesh - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 37
Ao todo: 19,117
