Ir para o conteúdo principal
Sony VAIO PCG-933A Keyboard Replacement
O que você precisa
  1. Sony VAIO PCG-933A Keyboard Replacement, Battery: passo 1, imagem 1 %32 Sony VAIO PCG-933A Keyboard Replacement, Battery: passo 1, imagem 2 %32
    • Turn the laptop upside down so that the top is sitting on a flat surface.
    • If you are looking at the bottom of the laptop the battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
    Pergunte ao FixBot
    Comentar
  2. Sony VAIO PCG-933A Keyboard Replacement: passo 2, imagem 1 %32 Sony VAIO PCG-933A Keyboard Replacement: passo 2, imagem 2 %32 Sony VAIO PCG-933A Keyboard Replacement: passo 2, imagem 3 %32
    • As shown by the arrow, slide the plastic cover up and then pull out and downwards.
    • You should now be able to pull the battery out.
    Pergunte ao FixBot
    Comentar
  3. Sony VAIO PCG-933A Keyboard Replacement, Keyboard: passo 3, imagem 1 %32
    • Remove the four 16 mm screws bordering the edge of the laptop using a Phillips #0 screwdriver.
    Pergunte ao FixBot
    Comentar
  4. Sony VAIO PCG-933A Keyboard Replacement: passo 4, imagem 1 %32 Sony VAIO PCG-933A Keyboard Replacement: passo 4, imagem 2 %32
    • Remove the 4mm screw on the right rear side of the laptop next to the audio ports using a Phillips #0 screwdriver.
    • This will release the speaker grille.
    Pergunte ao FixBot
    Comentar
  5. Sony VAIO PCG-933A Keyboard Replacement: passo 5, imagem 1 %32
    • Flip the computer so the key board is facing up.
    Pergunte ao FixBot
    Comentar
  6. Sony VAIO PCG-933A Keyboard Replacement: passo 6, imagem 1 %32 Sony VAIO PCG-933A Keyboard Replacement: passo 6, imagem 2 %32 Sony VAIO PCG-933A Keyboard Replacement: passo 6, imagem 3 %32
    • Slide the blue speaker grille (located above the keyboard) to the right and gently pull upward. The grille will still be connected by a white electrical strip.
    • Carefully pull out the white electrical strip. By doing this you will remove the speaker grille.
    Pergunte ao FixBot
    Comentar
  7. Sony VAIO PCG-933A Keyboard Replacement: passo 7, imagem 1 %32 Sony VAIO PCG-933A Keyboard Replacement: passo 7, imagem 2 %32 Sony VAIO PCG-933A Keyboard Replacement: passo 7, imagem 3 %32
    • Remove the 4mm screw in the center using a Phillips screwdriver.
    • Carefully and slowly pull the green strip straight up (away from the laptop) to disconnect it. Make sure not to pull too hard to avoid breaking.
    • The keyboard can now be removed.
    Pergunte ao FixBot
    Comentar
Conclusão
Sara Lillard
Membro desde: 04/11/11
165 Reputação
Autoria de 8 guias
Equipe
Cal Poly, Team 12-36, Maness Spring 2011 Membro de Cal Poly, Team 12-36, Maness Spring 2011
CPSU-MANESS-S11S12G36
4 Membros
Autoria de 16 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 39
Ao todo: 2,239
