Introdução
This guide is for those with a Sony VAIO PCG-3E2L laptop that no longer holds charge or their battery is damaged. This guide will walk you through the process of replacing the battery and extending the life of your laptop.
Before starting, power off your laptop and disconnect it from any power source. This replacement requires a new aftermarket battery and takes approximately 2 minutes. Follow these steps carefully to restore your laptop's battery life.
O que você precisa
First, locate the battery compartment found at the top, underneath the machine.
Use your thumbs to push the switch locks inward.
All that is required is for you to power off your laptop and disconnect it from any power source, then flip it around to open the battery cover using the lock switches with both thumbs, then swap the battery in the same orientation and install back the battery cover and secure it with the lock switches before resuming normal operations.
4 outras pessoas executaram este guia.
