Ir para o conteúdo principal
Sony Tablet S Charging Connector Replacement
O que você precisa
    1. Sony Tablet S Charging Connector Replacement, Battery: passo 1, imagem 1 %32 Sony Tablet S Charging Connector Replacement, Battery: passo 1, imagem 2 %32
      • Ensure that the device is completely turned off before attempting a repair. The battery may still have charge; use caution touching the components.
      • Use a plastic opening tool to remove the two rubber grips on the back of the tablet.
      Pergunte ao FixBot
      Comentar
    2. Sony Tablet S Charging Connector Replacement: passo 2, imagem 1 %32
      • Remove the two 10mm Phillips #0 screws located under the grips.
      Pergunte ao FixBot
      Comentar
    3. Sony Tablet S Charging Connector Replacement: passo 3, imagem 1 %32 Sony Tablet S Charging Connector Replacement: passo 3, imagem 2 %32
      • Flip the tablet over and use a plastic opening tool to pry the casing away from the top of the screen. Push the back cover off.
      • There is adhesive holding the case on located at the top of the screen. Push the casing toward the top of the screen while also wiggling it back and forth.
      Pergunte ao FixBot
      Comentar
    4. Sony Tablet S Charging Connector Replacement: passo 4, imagem 1 %32
      • Once the casing is off, remove the nine 5mm Phillips #0 screws shown.
      Pergunte ao FixBot
      Comentar
    5. Sony Tablet S Charging Connector Replacement: passo 5, imagem 1 %32
      • Remove the white ribbon cable by pulling the blue tab straight up out of the socket and then peeling up the tape securing it to the tablet.
      • Use caution when removing the cable, as the socket is very fragile.
      Pergunte ao FixBot
      Comentar
    6. Sony Tablet S Charging Connector Replacement: passo 6, imagem 1 %32
      • Remove the copper ribbon cable by gently using a spudger to pry it up from its socket.
      Pergunte ao FixBot
      Comentar
    7. Sony Tablet S Charging Connector Replacement: passo 7, imagem 1 %32
      • Slide the bottom grey cover piece away from the body and remove it.
      • If this piece gives resistance, use a spudger on the sides of the tablet to pry it loose.
      Pergunte ao FixBot
      Comentar
    8. Sony Tablet S Charging Connector Replacement: passo 8, imagem 1 %32
      • Remove the five 4mm Phillips #000 screws.
      • Remove the two 5mm Phillips #000 screws holding the charger in place.
      Pergunte ao FixBot
      Comentar
    9. Sony Tablet S Charging Connector Replacement: passo 9, imagem 1 %32 Sony Tablet S Charging Connector Replacement: passo 9, imagem 2 %32 Sony Tablet S Charging Connector Replacement: passo 9, imagem 3 %32
      • Position the charging port at an angle so you can thread it through the opening as you remove the black plastic cover from the back of the tablet.
      • If the cover is not coming off easily, use a plastic opening tool to pry it loose from the edges of the screen.
      Pergunte ao FixBot
      Comentar
    10. Sony Tablet S Charging Connector Replacement: passo 10, imagem 1 %32 Sony Tablet S Charging Connector Replacement: passo 10, imagem 2 %32
      • Use a spudger to lift the zero insertion force connector latch for the long ribbon cable to the right of the battery, then pull the cable loose from its socket.
      Pergunte ao FixBot
      Comentar
    11. Sony Tablet S Charging Connector Replacement: passo 11, imagem 1 %32
      • Remove the three 5mm Phillips #0 screws securing the original battery.
      Pergunte ao FixBot
      Comentar
    12. Sony Tablet S Charging Connector Replacement: passo 12, imagem 1 %32 Sony Tablet S Charging Connector Replacement: passo 12, imagem 2 %32
      • Use the spudger to pop the battery loose and remove the battery.
      Pergunte ao FixBot
      Comentar
    1. Sony Tablet S Charging Connector Replacement, Charging Connector: passo 13, imagem 1 %32 Sony Tablet S Charging Connector Replacement, Charging Connector: passo 13, imagem 2 %32
      • Unscrew the single 5mm Phillips #000 screw.
      Pergunte ao FixBot
      Comentar
    2. Sony Tablet S Charging Connector Replacement: passo 14, imagem 1 %32 Sony Tablet S Charging Connector Replacement: passo 14, imagem 2 %32
      • Peel up the tape securing the assembly.
      Pergunte ao FixBot
      Comentar
    3. Sony Tablet S Charging Connector Replacement: passo 15, imagem 1 %32 Sony Tablet S Charging Connector Replacement: passo 15, imagem 2 %32 Sony Tablet S Charging Connector Replacement: passo 15, imagem 3 %32
      • Use a spudger to disengage the zero insertion force latch securing the copper ribbon cable.
      • Pull away the ribbon cable.
      Pergunte ao FixBot
      Comentar
    4. Sony Tablet S Charging Connector Replacement: passo 16, imagem 1 %32 Sony Tablet S Charging Connector Replacement: passo 16, imagem 2 %32
      • Disconnect the charging assembly from the pin connector.
      • Pull on it very gently; the socket is very fragile.
      Pergunte ao FixBot
      Comentar
    5. Sony Tablet S Charging Connector Replacement: passo 17, imagem 1 %32
      • Remove the assembly.
      Pergunte ao FixBot
      Comentar
Conclusão
3 outras pessoas executaram este guia.
Austin Mann
Membro desde: 09/28/16
287 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 3-5, Passmore Fall 2016 Membro de USF Tampa, Team 3-5, Passmore Fall 2016
USFT-PASSMORE-F16S3G5
3 Membros
Autoria de 5 guias
1Comentário do guia
Thank you it helped me. :)
e_hlpr - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 45
Ao todo: 3,695
