Introdução
This guide will help users replace the battery on their Sony Tablet S. This requires a Phillips #0 and #000 screw driver, as well as a spudger and some plastic opening tools.
O que você precisa
Use a plastic opening tool to remove the two rubber grips on the back of the tablet.
4 outras pessoas executaram este guia.
1Comentário do guia
To change polarizer sticker of the screen, is it necessary to remove battery, motherboard etc. or I can just go with removing the adhesive of the bezel? Even after removing the bezel adhesive, is it easy to replace the sticker without damaging the lcd or digitizer?
