Ir para o conteúdo principal
Sony Smart Watch SW2 Display Assembly Replacement
O que você precisa
    1. Sony Smart Watch SW2 Display Assembly Replacement, Display Assembly: passo 1, imagem 1 %32
      • Detach the smart watch from the band by pushing on the back of the watch housing.
      • The power button may fall out once the smart watch is detached.
      • Set aside the power button and watch band as they are no longer needed for further disassembly.
      Pergunte ao FixBot
      Comentar
    2. Sony Smart Watch SW2 Display Assembly Replacement: passo 2, imagem 1 %32
      • Use a plastic opening tool to carefully pry the LCD screen from the watch housing.
      Pergunte ao FixBot
      Comentar
    3. Sony Smart Watch SW2 Display Assembly Replacement: passo 3, imagem 1 %32
      • Use a plastic opening tool or spudger to lift the screen assembly press-fit connector free.
      Pergunte ao FixBot
      Comentar
    4. Sony Smart Watch SW2 Display Assembly Replacement: passo 4, imagem 1 %32
      • Set aside the detached LCD screen to access the battery.
      Pergunte ao FixBot
      Comentar
Conclusão
To reassemble your device, follow these steps in reverse order.
3 outras pessoas executaram este guia.
Vincent Shiue
Membro desde: 01/22/18
265 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S1-G5, Freund Spring 2018 Membro de IUPUI, Team S1-G5, Freund Spring 2018
IUPUI-FREUND-S18S1G5
3 Membros
Autoria de 2 guias
1Comentário do guia
whwre can I get the LCD screen for SW2?
faizal ahamed - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 46
Ao todo: 3,585
