Introdução
This guide will teach you how to safely replace the battery for the Sony Smart Watch SW2.
O que você precisa
Detach the smart watch from the band by pushing on the back of the watch housing.
Lift one side of the battery up carefully. There is a thin black circuit adhered to the back of the battery that connects to the motherboard and the charger.
To reassemble your device, follow these instructions in reverse order after the battery is replaced.
3Comentários do guia
HI
please from where can i get the battery i want new one you know any website sell this battery
thanks
I think AliExpress has some compatible batteries. I may order one too.
Looked replacing battery but when I pushed the assembly free from the case I could see corrosion. Is it worth the trouble?
