Ir para o conteúdo principal
Sony SRS-XB43 Speaker Replacement
O que você precisa
  1. Sony SRS-XB43 Speaker Replacement, Faceplate: passo 1, imagem 1 %32 Sony SRS-XB43 Speaker Replacement, Faceplate: passo 1, imagem 2 %32
    • Insert the metal spudger into the mesh's seam/opening located at the bottom of the speaker.
    • Begin applying pressure, prying along the run of the seam until the mesh cover begins to come loose.
    • Fully open the hinged mesh cover and pry it off the unit.
  2. Sony SRS-XB43 Speaker Replacement: passo 2, imagem 1 %32
    • Turn the speaker so the back is facing you.
    • Remove the factory tamper seal below the speaker volume toggle to reveal a single screw.
    • Remove the single screw using a T8 Torx.
  3. Sony SRS-XB43 Speaker Replacement: passo 3, imagem 1 %32
    • Remove all ten screws using a Phillips #1 screwdriver.
  4. Sony SRS-XB43 Speaker Replacement: passo 4, imagem 1 %32 Sony SRS-XB43 Speaker Replacement: passo 4, imagem 2 %32
    • Slowly lift the speaker face off of the housing unit.
    • Unplug the six wires connecting the faceplate to the motherboard.
  5. Sony SRS-XB43 Speaker Replacement, Speaker: passo 5, imagem 1 %32 Sony SRS-XB43 Speaker Replacement, Speaker: passo 5, imagem 2 %32 Sony SRS-XB43 Speaker Replacement, Speaker: passo 5, imagem 3 %32
    • On the face plate of the speaker, locate the black ribbon cable plugged into the green circuit board to your right.
    • Grab the ribbon cable from its base and apply a light verticle force upwards to unplug it from the PCB.
    • This step prevents the cable from getting in the way of the right speaker as it is being removed.
  6. Sony SRS-XB43 Speaker Replacement: passo 6, imagem 1 %32
    • Remove eight black 10 mm screws attached to the speaker plate using a Phillips #1 screwdriver.
  7. Sony SRS-XB43 Speaker Replacement: passo 7, imagem 1 %32 Sony SRS-XB43 Speaker Replacement: passo 7, imagem 2 %32
    • Remove the two individual speakers.
Conclusão
Uma outra pessoa concluiu este guia.
Bishoy Mikhail
Membro desde: 10/26/22
253 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 3-5, Botvin Fall 2022 Membro de UMass Dartmouth, Team 3-5, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G5
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 15
Últimos 30 dias: 53
Duração total: 991
