Ir para o conteúdo principal
Sony SRS-XB43 Battery Replacement
O que você precisa
  1. Sony SRS-XB43 Battery Replacement, Faceplate: passo 1, imagem 1 %32 Sony SRS-XB43 Battery Replacement, Faceplate: passo 1, imagem 2 %32
    • Insert the metal spudger into the mesh's seam/opening located at the bottom of the speaker.
    • Begin applying pressure, prying along the run of the seam until the mesh cover begins to come loose.
    • Fully open the hinged mesh cover and pry it off the unit.
  2. Sony SRS-XB43 Battery Replacement: passo 2, imagem 1 %32
    • Turn the speaker so the back is facing you.
    • Remove the factory tamper seal below the speaker volume toggle to reveal a single screw.
    • Remove the single screw using a T8 Torx.
  3. Sony SRS-XB43 Battery Replacement: passo 3, imagem 1 %32
    • Remove all ten screws using a Phillips #1 screwdriver.
  4. Sony SRS-XB43 Battery Replacement: passo 4, imagem 1 %32 Sony SRS-XB43 Battery Replacement: passo 4, imagem 2 %32
    • Slowly lift the speaker face off of the housing unit.
    • Unplug the six wires connecting the faceplate to the motherboard.
  5. Sony SRS-XB43 Battery Replacement, Battery: passo 5, imagem 1 %32 Sony SRS-XB43 Battery Replacement, Battery: passo 5, imagem 2 %32
    • Orient the speaker's backplate so that the plastic chassis and internal electronics are facing upwards.
    • Remove the eight 10 mm screws securing the motherboard chassis to the backplate using a Phillips #1 screwdriver.
    • Grab the motherboard chassis and gently remove it from the backplate of the speaker.
  6. Sony SRS-XB43 Battery Replacement: passo 6, imagem 1 %32 Sony SRS-XB43 Battery Replacement: passo 6, imagem 2 %32 Sony SRS-XB43 Battery Replacement: passo 6, imagem 3 %32
    • Orient the motherboard chassis so that the side with the six buttons is facedown on the table and the opposite side is visible to you.
    • Disconnect the seven-prong cable (the one with red, yellow, and black wires) plugged into the motherboard by prying on its edge/extruding lip with a spudger.
  7. Sony SRS-XB43 Battery Replacement: passo 7, imagem 1 %32 Sony SRS-XB43 Battery Replacement: passo 7, imagem 2 %32
    • Orient the plastic chassis so that the port housing PCB is facing upward.
    • Remove the plastic black film covering the battery, leaving the blue battery exposed.
  8. Sony SRS-XB43 Battery Replacement: passo 8, imagem 1 %32 Sony SRS-XB43 Battery Replacement: passo 8, imagem 2 %32
    • Lightly pull the seven-prong cable upwards until the battery is angled in such a way that you can get a proper grip on both sides with your fingers.
    • Using your fingers, pull upwards until the battery is removed from its enclosure.
    • Do not use a spudger or other flat tools to pry in between the seam of the battery and the battery compartment, as it is possible to damage the battery.
Conclusão
Luke Escobar
Membro desde: 10/28/22
159 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 3-5, Botvin Fall 2022 Membro de UMass Dartmouth, Team 3-5, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G5
Membros da 4
Autoria de 5 guias
Um comentário
So, where can we buy a new battery to use these instructions for replacing it ?
Doubletap - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 33
Últimos 30 dias: 166
Duração total: 2,295
