Ir para o conteúdo principal
Sony Pulse Elite Edition Battery Replacement
O que você precisa
  1. Sony Pulse Elite Edition Battery Replacement, Identifying Earpiece: passo 1, imagem 1 %32
    • Locate the left side designation on the headband-earpiece junction.
    • The battery is in the right earpiece.
    • The motherboard is in the left earpiece.
    Pergunte ao FixBot
    Comentar
  2. Sony Pulse Elite Edition Battery Replacement, Ear Cushion Removal: passo 2, imagem 1 %32 Sony Pulse Elite Edition Battery Replacement, Ear Cushion Removal: passo 2, imagem 2 %32
    • Gently pull around the perimeter of the left ear cushion until it comes off.
    Pergunte ao FixBot
    Comentar
  3. Sony Pulse Elite Edition Battery Replacement, Outer Ear Rim Removal: passo 3, imagem 1 %32 Sony Pulse Elite Edition Battery Replacement, Outer Ear Rim Removal: passo 3, imagem 2 %32
    • Use the PH00 Screwdriver to remove the three Phillips 6mm screws around the perimeter of the ear cup.
    • Gently pull the outer ear rim off of the headset assembly.
    • Harsh removal may cause permanent damage to the speaker wires.
    Pergunte ao FixBot
    Comentar
  4. Sony Pulse Elite Edition Battery Replacement, Remove Speaker Housing: passo 4, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Using tweezers, gently pry the red and black speaker wires from the attached socket.
    Pergunte ao FixBot
    Comentar
  5. Sony Pulse Elite Edition Battery Replacement, Remove Battery: passo 5, imagem 1 %32 Sony Pulse Elite Edition Battery Replacement, Remove Battery: passo 5, imagem 2 %32
    • Lift up battery and disconnect wires using tweezers.
    • Use a new battery for reconstruction.
    Pergunte ao FixBot
    Comentar
Conclusão
8 outras pessoas executaram este guia.
Chris Echter
Membro desde: 01/29/15
871 Reputação
Autoria de 4 guias
8Comentários do guia
Where can I buy the replacement battery for this?
Pretty hard to find...
francisklalumiere - Responder Compartilhar
Replacement batteries can be found by googling "SP70C battery". It is a Lithium battery with 900mAh and a 3.7v output. AliExpress shows them for $11 including shipping.
David McAndrews - Responder Compartilhar
Can I mod and replace the battery with a bigger one with no white connection, just positive and negative? Thanks!
marit - Responder Compartilhar
Thank you so much for this guide. I got a 1000mAh batter from Amazon for 10 dollars. It lasts way longer and was extremely easy to install. Very thankful for this. Thanks!
sharku19z - Responder Compartilhar
i just attempted... the connector to the battery just pulled off. NOTE: Pull up from PCB not out. The connector sets down into it.
Garrett Parmenter - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 32
Últimos 30 dias: 155
Ao todo: 14,047
