Ir para o conteúdo principal
Sony PlayStation Camera Microphone Array Replacement
O que você precisa
  1. Sony PlayStation Camera Microphone Array Replacement, Microphone Array: passo 1, imagem 1 %32 Sony PlayStation Camera Microphone Array Replacement, Microphone Array: passo 1, imagem 2 %32
    • Separate the camera from the camera stand to gain access to the bottom of the camera.
    Pergunte ao FixBot
    Comentar
  2. Sony PlayStation Camera Microphone Array Replacement: passo 2, imagem 1 %32 Sony PlayStation Camera Microphone Array Replacement: passo 2, imagem 2 %32
    • With the PH000 sized screwdriver, remove the two 6.5mm Phillips #000 screws located under the stand connection point, where the cable enters the case.
    Pergunte ao FixBot
    Comentar
  3. Sony PlayStation Camera Microphone Array Replacement: passo 3, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Using tweezers, remove the cap holding the cable grommet in place.
    Pergunte ao FixBot
    Comentar
  4. Sony PlayStation Camera Microphone Array Replacement: passo 4, imagem 1 %32
    • Using the tweezers, remove both poly-carbonate lens coverplates.
    • Lift the coverplates slowly, to ensure they do not crack, or break.
    Pergunte ao FixBot
    Comentar
  5. Sony PlayStation Camera Microphone Array Replacement: passo 5, imagem 1 %32 Sony PlayStation Camera Microphone Array Replacement: passo 5, imagem 2 %32
    • Using the PH0 sized screwdriver, remove two 3.2mm Phillips #0 screws, located under the coverplates.
    Pergunte ao FixBot
    Comentar
  6. Sony PlayStation Camera Microphone Array Replacement: passo 6, imagem 1 %32
    • Using extreme care, separate the front of the case, from the back with a metal spudger, or pry tool. The case will scratch easily.
    • The case joints can be hard to spot. They appear as a very fine line in the plastic. Start with light pressure until the seam parts, allowing the pry tool to work.
    Pergunte ao FixBot
    Comentar
  7. Sony PlayStation Camera Microphone Array Replacement: passo 7, imagem 1 %32 Sony PlayStation Camera Microphone Array Replacement: passo 7, imagem 2 %32
    • Using the PH0 sized screwdriver, remove the four 4.5mm Phillips #0 screws securing the circuit assembly to the device housing.
    Pergunte ao FixBot
    Comentar
  8. Sony PlayStation Camera Microphone Array Replacement: passo 8, imagem 1 %32 Sony PlayStation Camera Microphone Array Replacement: passo 8, imagem 2 %32 Sony PlayStation Camera Microphone Array Replacement: passo 8, imagem 3 %32
    • Lift the motherboard and frame from the plastic housing.
    • Disconnect the camera cable from the motherboard.
    Pergunte ao FixBot
    Comentar
  9. Sony PlayStation Camera Microphone Array Replacement: passo 9, imagem 1 %32 Sony PlayStation Camera Microphone Array Replacement: passo 9, imagem 2 %32
    • Using the PH0 sized screwdriver, remove the six 4.2mm Phillips #0 screws securing the motherboard to the metal frame.
    Pergunte ao FixBot
    Comentar
  10. Sony PlayStation Camera Microphone Array Replacement: passo 10, imagem 1 %32 Sony PlayStation Camera Microphone Array Replacement: passo 10, imagem 2 %32
    • Using a plastic opening tool, disconnect the microphone array connector from the motherboard.
    Pergunte ao FixBot
    Comentar
  11. Sony PlayStation Camera Microphone Array Replacement: passo 11, imagem 1 %32 Sony PlayStation Camera Microphone Array Replacement: passo 11, imagem 2 %32 Sony PlayStation Camera Microphone Array Replacement: passo 11, imagem 3 %32
    • Using fine point tweezers, grab hold of each microphone, one at a time, and lift from the plastic frame.
    • Using care to not damage the wires, remove microphone array from the retaining tabs on the plastic frame.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Joshua Gates
Membro desde: 02/15/17
268 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 5-5, Passmore Spring 2017 Membro de USF Tampa, Team 5-5, Passmore Spring 2017
USFT-PASSMORE-S17S5G5
3 Membros
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 11
Últimos 30 dias: 74
Ao todo: 7,776
