Ir para o conteúdo principal
Sony NWZ-E473 Battery Replacement
O que você precisa
  1. Sony NWZ-E473 Battery Replacement, Back Panel: passo 1, imagem 1 %32
    • Use a Phillips #00 screwdriver to unscrew the two 5 mm screws located on the bottom of the back of the device.
    Pergunte ao FixBot
    Comentar
  2. Sony NWZ-E473 Battery Replacement: passo 2, imagem 1 %32
    • Use a plastic opening tool to loosen the bottom portion of device.
    Pergunte ao FixBot
    Comentar
  3. Sony NWZ-E473 Battery Replacement: passo 3, imagem 1 %32
    • Use a plastic opening tool to loosen the top panel of the device.
    Pergunte ao FixBot
    Comentar
  4. Sony NWZ-E473 Battery Replacement: passo 4, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the two 3 mm screws located on the portion under the top panel of the device.
    Pergunte ao FixBot
    Comentar
  5. Sony NWZ-E473 Battery Replacement: passo 5, imagem 1 %32 Sony NWZ-E473 Battery Replacement: passo 5, imagem 2 %32 Sony NWZ-E473 Battery Replacement: passo 5, imagem 3 %32
    • Remove the back plate from the device.
    Pergunte ao FixBot
    Comentar
  6. Sony NWZ-E473 Battery Replacement, Battery: passo 6, imagem 1 %32 Sony NWZ-E473 Battery Replacement, Battery: passo 6, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Peel back the layer of tape along with the processor, which is located just below the battery, using the tweezers and the spudger.
    Pergunte ao FixBot
    Comentar
  7. Sony NWZ-E473 Battery Replacement: passo 7, imagem 1 %32 Sony NWZ-E473 Battery Replacement: passo 7, imagem 2 %32
    • Slide a prying tool underneath the top portion of the battery and lift it from the case.
    Pergunte ao FixBot
    Comentar
  8. Sony NWZ-E473 Battery Replacement: passo 8, imagem 1 %32
    • Remove the stickers from the battery terminals, which are on the underside of the battery.
    Pergunte ao FixBot
    Comentar
  9. Sony NWZ-E473 Battery Replacement: passo 9, imagem 1 %32
    • Use a soldering iron to remove the wires from the red and the black terminals.
    Pergunte ao FixBot
    Comentar
Conclusão
5 outras pessoas executaram este guia.
Matthew Hintz
Membro desde: 01/16/15
330 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 17-6, Watkins Winter 2015 Membro de USF Tampa, Team 17-6, Watkins Winter 2015
USFT-WATKINS-W15S17G6
4 Membros
Autoria de 7 guias
3Comentários do guia
Hi their I have a Sony nwz-e355 walkman I want to replace the battery in it cause I thinks it's done I see u do a replacement for the e473 wondering if u have e355 batteries or will this e473 battery work in my walkman both need to be soildered in any feed back would help
Derek Hebert - Responder Compartilhar
I have the same model. I have 2 of them purchased years ago from Ubid.com. A very cool device. SONY ought to service them when the batteries fade…
guy lewit - Responder Compartilhar
Hello, if I want to attempt this replacement, where is the best way to buy such a battery? Thank you!
Juliette FD - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 29
Últimos 30 dias: 139
Ao todo: 11,436
