Introdução
When removing the screen, you may want to use gloves so that no glass shards cut your hands.
O que você precisa
Use a Phillips #00 screwdriver to unscrew the two 5 mm screws located on the bottom of the back of the device.
Ferramenta utilizada neste passo:Tweezers$4.99
Use a nylon spudger or tweezers to remove the plastic USB cover.
