Ir para o conteúdo principal
Sony NEX-7 Battery Replacement
    1. Sony NEX-7 Battery Replacement, Battery: passo 1, imagem 1 %32 Sony NEX-7 Battery Replacement, Battery: passo 1, imagem 2 %32
      • We need to turn off the camera because we are removing components that could get damaged if the power is still on.
      • If the camera is on, rotate the power switch on top of the camera counterclockwise to turn the camera off.
      Pergunte ao FixBot
      Comentar
    2. Sony NEX-7 Battery Replacement: passo 2, imagem 1 %32
      • Flip the camera over such that the power switch points down.
      • Slide the switch on the bottom of the camera grip towards the lens to open the battery door.
      Pergunte ao FixBot
      Comentar
    3. Sony NEX-7 Battery Replacement: passo 3, imagem 1 %32
      • With the battery door open, push the blue lever in the battery compartment to release the battery.
      Pergunte ao FixBot
      Comentar
Conclusão
To replace the battery, fit it in the slot, then close and lock the door.
Tyler
Membro desde: 04/22/14
578 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 10-55, Amido Spring 2014 Membro de Cal Poly, Team 10-55, Amido Spring 2014
CPSU-AMIDO-S14S10G55
4 Membros
Autoria de 46 guias
1Comentário do guia
I’ve done this about a million times. :)
Martin Hurley - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 34
Ao todo: 2,873
