Introdução
Here is a Sony TV that turned on and off every few seconds. To remedy this, replace the lamp. This is straight forward and only requires a small Allen wrench. As with all work on all electric or electronic equipment, make sure that it is unplugged first.
O que você precisa
With both thumb screws removed, the front bezel can now be easily pulled off. It is only held in place by three magnets.
With the bezel out of the way, there will be a small cover held in place by a crossbar and a thumb screw. Loosen the thumb screw and fold the bar out of the way.
The back of the lamp housing is now visible.
13 outras pessoas executaram este guia.
17 comentários
Where did you purchase this bulb for $32?
Mine worked 4 3 hours then stayed off.
A y solutions
Thanks a lot. You saved me money
THANK YOU! Helped me save so much money! I did it all by myself!
looking for a bulb...where is the best price
Thank you SOOO much! Hubby has been sayin for almost 2 years that he’d fix it when the tv started glitching. Well he didn’t, and I got tired of looking at this huge eyesore in the living room. So, I figured I’ll do it my dang self…he’s sitting here quiet, as he sees how simple and cheap this repair is. So annoyed with the repairing procrastinating he does all the time. Love him, but he hates fixing stuff :) Thanks again!!
Antoinette Noelien glad this guide worked for you and that you got your TV back.
My TV picture is dim do I need to replace theclamp
Your advice was spot on. It took 5 minutes to do everything and now I'm back up and running in my man cave!!!
Bulb is replaced , but no sound and no picture.
How to find my problem,the bulb is new but I have no sound and no picture. What is the problem?
Why I don't have sound,and no picture after replacing the bulb
