Ir para o conteúdo principal
Sony ICF-C1T Tuner Dial Replacement
O que você precisa
  1. Sony ICF-C1T Tuner Dial Replacement, Tuner Dial: passo 1, imagem 1 %32
    • Using the Phillips #00 screwdriver, remove four 14mm screws from the underside of the device.
    • Make sure that the clock is unplugged and the battery is removed before tampering with the device to avoid electrical shock.
    Pergunte ao FixBot
    Comentar
  2. Sony ICF-C1T Tuner Dial Replacement: passo 2, imagem 1 %32
    • Use the opening tool to pry apart the edges of the top and side portions of the device.
    Pergunte ao FixBot
    Comentar
  3. Sony ICF-C1T Tuner Dial Replacement: passo 3, imagem 1 %32 Sony ICF-C1T Tuner Dial Replacement: passo 3, imagem 2 %32
    • Separate the device by gently pulling up on the top portion.
    • Use caution when pulling the device apart as the clock display is located close to the front face plate and is connected by multiple wires.
    Pergunte ao FixBot
    Comentar
  4. Sony ICF-C1T Tuner Dial Replacement: passo 4, imagem 1 %32 Sony ICF-C1T Tuner Dial Replacement: passo 4, imagem 2 %32
    • To remove the motherboard, gently pull apart the sides of the device.
    • Do not pull hard on the motherboard, because it is still connected by multiple wires inside the device.
    • Be careful of sharp pieces on the motherboard.
    • Having help for this step might make things quicker and easier.
    Pergunte ao FixBot
    Comentar
  5. Sony ICF-C1T Tuner Dial Replacement: passo 5, imagem 1 %32 Sony ICF-C1T Tuner Dial Replacement: passo 5, imagem 2 %32 Sony ICF-C1T Tuner Dial Replacement: passo 5, imagem 3 %32
    • Remove the tuner dial by pulling it off of the motherboard. This can take a little force to remove.
    Pergunte ao FixBot
    Comentar
Conclusão
1Comentário do guia
Thanks, this was not fun but the guide helped.
Campbell Kerr - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 53
Ao todo: 2,479
