Ir para o conteúdo principal
Sony ICF-C1T Screen Replacement
O que você precisa
  1. Sony ICF-C1T Screen Replacement, Screen: passo 1, imagem 1 %32
    • Make sure the clock is unplugged from the wall and the replacement battery has been taken out of the clock to prevent harm to you and to the clock.
    • Use a Phillips 00 head screwdriver to remove the four 14 mm screws from the bottom of the clock.
    Pergunte ao FixBot
    Comentar
  2. Sony ICF-C1T Screen Replacement: passo 2, imagem 1 %32
    • Insert the plastic opening tool to pry apart the top and sides of the device gently.
    Pergunte ao FixBot
    Comentar
  3. Sony ICF-C1T Screen Replacement: passo 3, imagem 1 %32 Sony ICF-C1T Screen Replacement: passo 3, imagem 2 %32
    • Carefully pull the top of clock off as the clock display is located directly behind the face plate and is still connected by multiple wires.
    • Pull the top of the device away from the rest of the clock to expose the inside.
    Pergunte ao FixBot
    Comentar
  4. Sony ICF-C1T Screen Replacement: passo 4, imagem 1 %32 Sony ICF-C1T Screen Replacement: passo 4, imagem 2 %32
    • Do not use too much pressure on the plastic to not break it.
    • Add pressure to the inside of the screen so that a small area is loosened enough to be able to use an opening tool.
    • Use the plastic opening tool to separate the screen from the device.
    Pergunte ao FixBot
    Comentar
  5. Sony ICF-C1T Screen Replacement: passo 5, imagem 1 %32 Sony ICF-C1T Screen Replacement: passo 5, imagem 2 %32
    • Apply a tinted spray to dim the brightness once the tinted sheet is out of the way.
    • Another way to solve the brightness problem is to apply a tinted color sheet protector.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 36
Ao todo: 5,635
