Ir para o conteúdo principal
Sony H.ear On 2 Motherboard Replacement
O que você precisa
  1. Sony H.ear On 2 Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 Sony H.ear On 2 Motherboard Replacement, Motherboard: passo 1, imagem 2 %32
    • Start on the left side by using the plastic opening tool in the crease between the ear cup and plastic. Gently apply pressure until it separates.
    • Do not force any parts off as the plastic holders may snap off if too much pressure is applied.
  2. Sony H.ear On 2 Motherboard Replacement: passo 2, imagem 1 %32 Sony H.ear On 2 Motherboard Replacement: passo 2, imagem 2 %32
    • Use the JIS #00 Screwdriver to remove the 2 6.4mm screws holding in the motherboard.
  3. Sony H.ear On 2 Motherboard Replacement: passo 3, imagem 1 %32 Sony H.ear On 2 Motherboard Replacement: passo 3, imagem 2 %32 Sony H.ear On 2 Motherboard Replacement: passo 3, imagem 3 %32
    • De-solder all 18 wire-connections on the motherboard.
    • Record wire positions on board for proper connections when re-soldering the replacement board.
    • Do not overheat joints while de-soldering to prevent board damage.
    • Please see Como soldar e dessoldar contatos for help on soldering and desoldering connections.
  4. Sony H.ear On 2 Motherboard Replacement: passo 4, imagem 1 %32 Sony H.ear On 2 Motherboard Replacement: passo 4, imagem 2 %32
    • Disconnect the white ribbon cable by gently tugging on the white connector while holding the motherboard carefully in place.
  5. Sony H.ear On 2 Motherboard Replacement: passo 5, imagem 1 %32
    • Gently remove the old motherboard from the bracket assembly and replace and resolder motherboard.
Conclusão
Michael Long
Membro desde: 04/15/19
131 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S9-G11, Maness Spring 2019 Membro de Cal Poly, Team S9-G11, Maness Spring 2019
CPSU-MANESS-S19S9G11
Membros da 5
Autoria de 16 guias
Um comentário
where can i find a replacement motherboard for these headphones?
MTL - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 30
Duração total: 1,588
