Introdução
Learn how to replace the motherboard on your Sony H.ear On 2 headphones!
This guide focuses on replacing the motherboard component located in the left ear cup. This guide will require soldering and desoldering. Please see Como soldar e dessoldar contatos before you attempt to desolder and resolder necessary on the components. Although optional, it is recommended you remove the battery before operating on the device for safety reasons.
O que você precisa
Start on the left side by using the plastic opening tool in the crease between the ear cup and plastic. Gently apply pressure until it separates.
