Ir para o conteúdo principal
Sony FDL-220R Watchman Button Replacement
O que você precisa
  1. Sony FDL-220R Watchman Button Replacement, Remove battery cover and batteries: passo 1, imagem 1 %32 Sony FDL-220R Watchman Button Replacement, Remove battery cover and batteries: passo 1, imagem 2 %32
    • Press down on the textured area and push towards the bottom of the device.
    • Gently remove the battery cover.
    • Remove the three AA batteries.
    Pergunte ao FixBot
    Comentar
  2. Sony FDL-220R Watchman Button Replacement, Remove screws: passo 2, imagem 1 %32 Sony FDL-220R Watchman Button Replacement, Remove screws: passo 2, imagem 2 %32
    • Locate the five 5x11mm screws surrounding the battery compartment.
    • Remove screws with a Philips #00 screwdriver.
    Pergunte ao FixBot
    Comentar
  3. Sony FDL-220R Watchman Button Replacement, Remove back casing: passo 3, imagem 1 %32 Sony FDL-220R Watchman Button Replacement, Remove back casing: passo 3, imagem 2 %32
    • Grasp the entire back half of the Watchman's casing.
    • Snap off the casing from the bottom of the device.
    • Gently pull off entire back casing.
    Pergunte ao FixBot
    Comentar
  4. Sony FDL-220R Watchman Button Replacement, Remove circuit board: passo 4, imagem 1 %32 Sony FDL-220R Watchman Button Replacement, Remove circuit board: passo 4, imagem 2 %32 Sony FDL-220R Watchman Button Replacement, Remove circuit board: passo 4, imagem 3 %32
    • Carefully grasp the entire circuit board.
    • Pull the circuit board off of the device's plastic casing.
    Pergunte ao FixBot
    Comentar
  5. Sony FDL-220R Watchman Button Replacement, Remove/Replace Buttons: passo 5, imagem 1 %32 Sony FDL-220R Watchman Button Replacement, Remove/Replace Buttons: passo 5, imagem 2 %32
    • Locate the thee plastic buttons/switches on the sides of the plastic grey casing.
    • Buttons/switches should be simply resting in their slots on the device.
    • Remove all three buttons/switches.
    • If the buttons/switches are dirty, clean them in warm water and dry thoroughly.
    • If one of the buttons/switches is broken, simply replace it with a new one.
    • When replacing, make sure that the slot on the switches faces up.
    Pergunte ao FixBot
    Comentar
Conclusão
Sam Putnam
Membro desde: 10/22/14
484 Reputação
Autoria de 4 guias
Equipe
Baylor, Team 4-5, Williams Fall 2014 Membro de Baylor, Team 4-5, Williams Fall 2014
BU-WILLIAMS-F14S4G5
4 Membros
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 33
Ao todo: 537
