Ir para o conteúdo principal
Sony FDL-220R Watchman Antenna Replacement
O que você precisa
  1. Sony FDL-220R Watchman Antenna Replacement, Remove battery cover and batteries: passo 1, imagem 1 %32 Sony FDL-220R Watchman Antenna Replacement, Remove battery cover and batteries: passo 1, imagem 2 %32
    • Press down on the textured area and push towards the bottom of the device.
    • Gently remove the battery cover.
    • Remove the three AA batteries.
  2. Sony FDL-220R Watchman Antenna Replacement, Remove screws: passo 2, imagem 1 %32 Sony FDL-220R Watchman Antenna Replacement, Remove screws: passo 2, imagem 2 %32
    • Locate the five 5x11mm screws surrounding the battery compartment.
    • Remove screws with a Phillips #00 screwdriver.
  3. Sony FDL-220R Watchman Antenna Replacement, Remove back casing: passo 3, imagem 1 %32 Sony FDL-220R Watchman Antenna Replacement, Remove back casing: passo 3, imagem 2 %32
    • Grasp the entire back half of the Watchman's casing.
    • Snap off the casing from the bottom of the device.
    • Gently pull off entire back casing.
    • Buttons may fall out upon opening casing. See the button replacement guide to fix buttons.
  4. Sony FDL-220R Watchman Antenna Replacement, Reattach antenna: passo 4, imagem 1 %32 Sony FDL-220R Watchman Antenna Replacement, Reattach antenna: passo 4, imagem 2 %32 Sony FDL-220R Watchman Antenna Replacement, Reattach antenna: passo 4, imagem 3 %32
    • Locate the two metal tabs which are meant to hold the antenna in place.
    • Pry back the metal tabs with a spudger.
    • Hook the antenna into the metal tab.
    • Ensure that the antenna is fully enclosed in the metal tab.
Conclusão
Sam Putnam
Membro desde: 10/22/14
484 Reputação
Autoria de 4 guias
Equipe
Baylor, Team 4-5, Williams Fall 2014 Membro de Baylor, Team 4-5, Williams Fall 2014
BU-WILLIAMS-F14S4G5
Membros da 4
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 19
Duração total: 496
