Ir para o conteúdo principal
Sony Ericsson W580i SIM Card Replacement
O que você precisa
  1. Sony Ericsson W580i SIM Card Replacement, Battery: passo 1, imagem 1 %32 Sony Ericsson W580i SIM Card Replacement, Battery: passo 1, imagem 2 %32 Sony Ericsson W580i SIM Card Replacement, Battery: passo 1, imagem 3 %32
    • Hold the phone with the screen facing down. Push the back cover firmly down and slide it towards you.
    • The panel will slide down about 2mm.
    • Lift the panel away from the phone.
    Pergunte ao FixBot
    Comentar
  2. Sony Ericsson W580i SIM Card Replacement: passo 2, imagem 1 %32
    • Lift the battery out from the bottom edge.
    Pergunte ao FixBot
    Comentar
  3. Sony Ericsson W580i SIM Card Replacement, SIM Card: passo 3, imagem 1 %32 Sony Ericsson W580i SIM Card Replacement, SIM Card: passo 3, imagem 2 %32 Sony Ericsson W580i SIM Card Replacement, SIM Card: passo 3, imagem 3 %32
    • Locate the SIM card slot.
    • Use a spudger to release the SIM card by pushing it in slightly until you feel a "click."
    • Release pressure from the SIM card. The SIM card will pop out about 5mm.
    Pergunte ao FixBot
    Comentar
  4. Sony Ericsson W580i SIM Card Replacement: passo 4, imagem 1 %32 Sony Ericsson W580i SIM Card Replacement: passo 4, imagem 2 %32
    • Slide the SIM card down out of the slot.
    • Remove the SIM card from the phone.
    Pergunte ao FixBot
    Comentar
Conclusão
Diego
Membro desde: 10/09/11
397 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 5-31, Amido Fall 2011 Membro de Cal Poly, Team 5-31, Amido Fall 2011
CPSU-AMIDO-F11S5G31
4 Membros
Autoria de 12 guias
2Comentários do guia
where do you get thease parts
Joy Martin - Responder Compartilhar
helllo i have an extremely big issue, i've been driving myself CRAZY for almost 6 years trying to figure out how to enter the sim card, i own one but i do not understand why its not fitting in, it's literally the exact same diameter as far as im concerned, hell i even tried it on another old phone AND IT DID FIT, i do not exactly have enough help online or presence to help me or guide me so could we email each other or something??? i really need this :(
Crossgrover Tv - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 92
Ao todo: 13,667
