Ir para o conteúdo principal
Sony Ericsson W200i Keypad Replacement
O que você precisa
  1. Sony Ericsson W200i Keypad Replacement, Disassembling Sony Ericsson W200i Battery: passo 1, imagem 1 %32 Sony Ericsson W200i Keypad Replacement, Disassembling Sony Ericsson W200i Battery: passo 1, imagem 2 %32
    • Slide the battery cover up and off the phone.
    Pergunte ao FixBot
    Comentar
  2. Sony Ericsson W200i Keypad Replacement: passo 2, imagem 1 %32 Sony Ericsson W200i Keypad Replacement: passo 2, imagem 2 %32
    • Pop the battery out of its slot by lifting it up.
    Pergunte ao FixBot
    Comentar
  3. Sony Ericsson W200i Keypad Replacement, Front Case: passo 3, imagem 1 %32 Sony Ericsson W200i Keypad Replacement, Front Case: passo 3, imagem 2 %32 Sony Ericsson W200i Keypad Replacement, Front Case: passo 3, imagem 3 %32
    • Insert the plastic opening tool in between the front case and the back case.
    • Apply downward pressure to make the case lift upwards, thus popping the front case off.
    • Use caution when removing the front case. It may seem stuck but just ease it out.
    Pergunte ao FixBot
    Comentar
  4. Sony Ericsson W200i Keypad Replacement, Keypad: passo 4, imagem 1 %32 Sony Ericsson W200i Keypad Replacement, Keypad: passo 4, imagem 2 %32
    • Using the plastic opening tool, press down anywhere on the keypad to separate it from the front case.
    Pergunte ao FixBot
    Comentar
Conclusão
6 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 14-10, Forte Winter 2011 Membro de Cal Poly, Team 14-10, Forte Winter 2011
CPSU-FORTE-W11S14G10
5 Membros
Autoria de 16 guias
1Comentário do guia
Can you guys tell me where i do get parts for these legacy phones?My jostick died on this phone.Not working at all i only can use the keypad.
Janos Lazar - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 40
Ao todo: 5,914
