Ir para o conteúdo principal
Sony Ericsson W200i Back Case Replacement
O que você precisa
  1. Sony Ericsson W200i Back Case Replacement, Disassembling Sony Ericsson W200i Battery: passo 1, imagem 1 %32 Sony Ericsson W200i Back Case Replacement, Disassembling Sony Ericsson W200i Battery: passo 1, imagem 2 %32
    • Slide the battery cover up and off the phone.
    Pergunte ao FixBot
    Comentar
  2. Sony Ericsson W200i Back Case Replacement: passo 2, imagem 1 %32 Sony Ericsson W200i Back Case Replacement: passo 2, imagem 2 %32
    • Pop the battery out of its slot by lifting it up.
    Pergunte ao FixBot
    Comentar
  3. Sony Ericsson W200i Back Case Replacement, Front Case: passo 3, imagem 1 %32 Sony Ericsson W200i Back Case Replacement, Front Case: passo 3, imagem 2 %32 Sony Ericsson W200i Back Case Replacement, Front Case: passo 3, imagem 3 %32
    • Insert the plastic opening tool in between the front case and the back case.
    • Apply downward pressure to make the case lift upwards, thus popping the front case off.
    • Use caution when removing the front case. It may seem stuck but just ease it out.
    Pergunte ao FixBot
    Comentar
  4. Sony Ericsson W200i Back Case Replacement, Core: passo 4, imagem 1 %32 Sony Ericsson W200i Back Case Replacement, Core: passo 4, imagem 2 %32
    • Remove the 4 screws in the corners of the front of the phone using a T6 screwdriver.
    • Note that the top 2 screws are silver and the bottom 2 screws are black.
    Pergunte ao FixBot
    Comentar
  5. Sony Ericsson W200i Back Case Replacement: passo 5, imagem 1 %32 Sony Ericsson W200i Back Case Replacement: passo 5, imagem 2 %32 Sony Ericsson W200i Back Case Replacement: passo 5, imagem 3 %32
    • There is a black tab in the top left corner holding the core in place.
    • Remove the core by pulling straight up to prevent breaking the tab.
    Pergunte ao FixBot
    Comentar
  6. Sony Ericsson W200i Back Case Replacement, Back Case: passo 6, imagem 1 %32 Sony Ericsson W200i Back Case Replacement, Back Case: passo 6, imagem 2 %32 Sony Ericsson W200i Back Case Replacement, Back Case: passo 6, imagem 3 %32
    • Pull back on the indicated tab of the white plastic cover to unhook it from the top of the phone.
    • Using the plastic opening tool, undo the indicated clip on the bottom of the white plastic cover.
    • Remove the white plastic cover.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, put removed pieces into the new back casing, then follow the steps in reverse order.
Equipe
Cal Poly, Team 14-10, Forte Winter 2011 Membro de Cal Poly, Team 14-10, Forte Winter 2011
CPSU-FORTE-W11S14G10
5 Membros
Autoria de 16 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 44
Ao todo: 4,085
