Ir para o conteúdo principal
Sony DualSense Controller Middle Trim Replacement
O que você precisa
  1. Sony DualSense Controller Middle Trim Replacement, Unclip the right end of the middle trim: passo 1, imagem 1 %32 Sony DualSense Controller Middle Trim Replacement, Unclip the right end of the middle trim: passo 1, imagem 2 %32
    • Disconnect and power down your controller before you begin.
    • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
  2. Sony DualSense Controller Middle Trim Replacement, Unclip the lower-right edge of the middle trim: passo 2, imagem 1 %32 Sony DualSense Controller Middle Trim Replacement, Unclip the lower-right edge of the middle trim: passo 2, imagem 2 %32 Sony DualSense Controller Middle Trim Replacement, Unclip the lower-right edge of the middle trim: passo 2, imagem 3 %32
    • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
  3. Sony DualSense Controller Middle Trim Replacement, Unclip the left end of the middle trim: passo 3, imagem 1 %32 Sony DualSense Controller Middle Trim Replacement, Unclip the left end of the middle trim: passo 3, imagem 2 %32
    • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
  4. Sony DualSense Controller Middle Trim Replacement, Unclip the lower-left edge of the middle trim: passo 4, imagem 1 %32 Sony DualSense Controller Middle Trim Replacement, Unclip the lower-left edge of the middle trim: passo 4, imagem 2 %32 Sony DualSense Controller Middle Trim Replacement, Unclip the lower-left edge of the middle trim: passo 4, imagem 3 %32
    • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
  5. Sony DualSense Controller Middle Trim Replacement, Remove the middle trim: passo 5, imagem 1 %32 Sony DualSense Controller Middle Trim Replacement, Remove the middle trim: passo 5, imagem 2 %32 Sony DualSense Controller Middle Trim Replacement, Remove the middle trim: passo 5, imagem 3 %32
    • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
    • Lift the middle trim over the joysticks to remove it.
Conclusão
6 outras pessoas executaram este guia.
Sam Omiotek
Membro desde: 02/25/19
76.055 Reputação
Autoria de 288 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 65
Últimos 30 dias: 311
Duração total: 7,302
