Ir para o conteúdo principal
Sony DualSense Controller Light Guide Replacement
O que você precisa
  1. Sony DualSense Controller Light Guide Replacement, Unclip the right end of the middle trim: passo 1, imagem 1 %32 Sony DualSense Controller Light Guide Replacement, Unclip the right end of the middle trim: passo 1, imagem 2 %32
    • Disconnect and power down your controller before you begin.
    • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
  2. Sony DualSense Controller Light Guide Replacement, Unclip the lower-right edge of the middle trim: passo 2, imagem 1 %32 Sony DualSense Controller Light Guide Replacement, Unclip the lower-right edge of the middle trim: passo 2, imagem 2 %32 Sony DualSense Controller Light Guide Replacement, Unclip the lower-right edge of the middle trim: passo 2, imagem 3 %32
    • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
  3. Sony DualSense Controller Light Guide Replacement, Unclip the left end of the middle trim: passo 3, imagem 1 %32 Sony DualSense Controller Light Guide Replacement, Unclip the left end of the middle trim: passo 3, imagem 2 %32
    • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
  4. Sony DualSense Controller Light Guide Replacement, Unclip the lower-left edge of the middle trim: passo 4, imagem 1 %32 Sony DualSense Controller Light Guide Replacement, Unclip the lower-left edge of the middle trim: passo 4, imagem 2 %32 Sony DualSense Controller Light Guide Replacement, Unclip the lower-left edge of the middle trim: passo 4, imagem 3 %32
    • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
  5. Sony DualSense Controller Light Guide Replacement, Remove the middle trim: passo 5, imagem 1 %32 Sony DualSense Controller Light Guide Replacement, Remove the middle trim: passo 5, imagem 2 %32 Sony DualSense Controller Light Guide Replacement, Remove the middle trim: passo 5, imagem 3 %32
    • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
    • Lift the middle trim over the joysticks to remove it.
  6. Sony DualSense Controller Light Guide Replacement, Remove the L1 button: passo 6, imagem 1 %32 Sony DualSense Controller Light Guide Replacement, Remove the L1 button: passo 6, imagem 2 %32 Sony DualSense Controller Light Guide Replacement, Remove the L1 button: passo 6, imagem 3 %32
    • With one hand, grip the controller and use your thumb to hold down the left trigger.
    • With your free hand, insert the flat end of a spudger between the L1 and L2 buttons.
    • Use the spudger to gently pry the L1 button away from the controller and remove it, holding your finger over the button so it doesn't eject.
  7. Sony DualSense Controller Light Guide Replacement, Remove the R1 button: passo 7, imagem 1 %32 Sony DualSense Controller Light Guide Replacement, Remove the R1 button: passo 7, imagem 2 %32 Sony DualSense Controller Light Guide Replacement, Remove the R1 button: passo 7, imagem 3 %32
    • Repeat the previous step to remove the R1 button.
  8. Sony DualSense Controller Light Guide Replacement, Remove the rear case screws: passo 8, imagem 1 %32 Sony DualSense Controller Light Guide Replacement, Remove the rear case screws: passo 8, imagem 2 %32
    • Use a Phillips screwdriver to remove the two 6.4 mm screws securing the bottom corners of the lower case.
  9. Sony DualSense Controller Light Guide Replacement: passo 9, imagem 1 %32 Sony DualSense Controller Light Guide Replacement: passo 9, imagem 2 %32
    • Use a Phillips screwdriver to remove the two 6.4 mm screws behind the L1 and R1 buttons.
  10. Sony DualSense Controller Light Guide Replacement, Separate the rear case: passo 10, imagem 1 %32 Sony DualSense Controller Light Guide Replacement, Separate the rear case: passo 10, imagem 2 %32 Sony DualSense Controller Light Guide Replacement, Separate the rear case: passo 10, imagem 3 %32
    • Be gentle when releasing the rear cover clips—they're delicate and can easily break.
    • Use the point of a spudger to release the two clips on either side of the headset jack.
  11. Sony DualSense Controller Light Guide Replacement: passo 11, imagem 1 %32 Sony DualSense Controller Light Guide Replacement: passo 11, imagem 2 %32 Sony DualSense Controller Light Guide Replacement: passo 11, imagem 3 %32
    • Tight plastic clips secure the left and right edges of the rear case.
    • Insert the flat end of a spudger between the front and rear shells near the bottom of the left edge.
    • Slide the spudger along the left edge and gently pry the shells apart to release the clips.
  12. Sony DualSense Controller Light Guide Replacement: passo 12, imagem 1 %32 Sony DualSense Controller Light Guide Replacement: passo 12, imagem 2 %32 Sony DualSense Controller Light Guide Replacement: passo 12, imagem 3 %32
    • Repeat the previous step on the right edge to release its clips.
  13. Sony DualSense Controller Light Guide Replacement: passo 13, imagem 1 %32 Sony DualSense Controller Light Guide Replacement: passo 13, imagem 2 %32
    • Lay your controller upside down so the joysticks are on your work surface.
    • Hold the controller down with your fingers and use your thumbs to lift the rear case away from the controller to fully separate it.
  14. Sony DualSense Controller Light Guide Replacement, Remove the rear case: passo 14, imagem 1 %32
    • Remove the rear case.
  15. Sony DualSense Controller Light Guide Replacement, Disconnect the battery: passo 15, imagem 1 %32 Sony DualSense Controller Light Guide Replacement, Disconnect the battery: passo 15, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use a pair of tweezers or your fingers to disconnect the battery from the motherboard.
    • Grip the connector, not the wires, when disconnecting.
  16. Sony DualSense Controller Light Guide Replacement, Remove the battery: passo 16, imagem 1 %32 Sony DualSense Controller Light Guide Replacement, Remove the battery: passo 16, imagem 2 %32
    • Lift the battery straight out of the battery bracket.
  17. Sony DualSense Controller Light Guide Replacement, Remove the lower microphone: passo 17, imagem 1 %32 Sony DualSense Controller Light Guide Replacement, Remove the lower microphone: passo 17, imagem 2 %32
    • Grab the lower microphone ribbon cable pull tab with your fingers or a pair of tweezers and disconnect it from the motherboard.
  18. Sony DualSense Controller Light Guide Replacement, Remove the battery bracket: passo 18, imagem 1 %32 Sony DualSense Controller Light Guide Replacement, Remove the battery bracket: passo 18, imagem 2 %32
    • Use a Phillips screwdriver to remove the 6.4 mm screw securing the battery bracket.
  19. Sony DualSense Controller Light Guide Replacement: passo 19, imagem 1 %32 Sony DualSense Controller Light Guide Replacement: passo 19, imagem 2 %32
    • Lift the battery bracket out of the motherboard.
  20. Sony DualSense Controller Light Guide Replacement, Disconnect the right trigger assembly: passo 20, imagem 1 %32 Sony DualSense Controller Light Guide Replacement, Disconnect the right trigger assembly: passo 20, imagem 2 %32
    • Grip the right trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers and pull up to disconnect it from the motherboard.
    • Do not completely remove the ribbon cable yet.
  21. Sony DualSense Controller Light Guide Replacement: passo 21, imagem 1 %32 Sony DualSense Controller Light Guide Replacement: passo 21, imagem 2 %32
    • Grip the right trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers, and pull up to disconnect it from the trigger assembly.
    • Remove the ribbon cable.
  22. Sony DualSense Controller Light Guide Replacement, Disconnect the left trigger assembly: passo 22, imagem 1 %32 Sony DualSense Controller Light Guide Replacement, Disconnect the left trigger assembly: passo 22, imagem 2 %32
    • Grip the left trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers and pull up to disconnect it from the motherboard.
  23. Sony DualSense Controller Light Guide Replacement: passo 23, imagem 1 %32 Sony DualSense Controller Light Guide Replacement: passo 23, imagem 2 %32
    • Grip the left trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers, and pull up to disconnect it from the trigger assembly.
  24. Sony DualSense Controller Light Guide Replacement, Disconnect the upper microphone: passo 24, imagem 1 %32 Sony DualSense Controller Light Guide Replacement, Disconnect the upper microphone: passo 24, imagem 2 %32
    • Use a pair of tweezers or your fingers to grip the upper microphone ribbon cable pull tab, and pull up to disconnect it from the motherboard.
  25. Sony DualSense Controller Light Guide Replacement, Disconnect the touchpad: passo 25, imagem 1 %32 Sony DualSense Controller Light Guide Replacement, Disconnect the touchpad: passo 25, imagem 2 %32
    • Use a pair of tweezers or your fingers to grip the touchpad ribbon cable pull tab, and pull it straight out of the motherboard connector.
  26. Sony DualSense Controller Light Guide Replacement, Lift out the motherboard: passo 26, imagem 1 %32 Sony DualSense Controller Light Guide Replacement, Lift out the motherboard: passo 26, imagem 2 %32 Sony DualSense Controller Light Guide Replacement, Lift out the motherboard: passo 26, imagem 3 %32
    • Carefully guide the joysticks through the front case and lift the motherboard out.
    • The motherboard is held down by two clips. One between the motherboard itself and the right trigger assembly, and one between the motherboard itself and the left trigger assembly. Gently push on either clip to release the motherboard from its restraints.
    • Do not completely remove the motherboard. There are four soldered wires tethering the motherboard to the vibrator motors.
  27. Sony DualSense Controller Light Guide Replacement, Remove the light guide: passo 27, imagem 1 %32 Sony DualSense Controller Light Guide Replacement, Remove the light guide: passo 27, imagem 2 %32
    • Use a Phillips screwdriver to remove the two 8.5 mm screws securing the light guide.
  28. Sony DualSense Controller Light Guide Replacement: passo 28, imagem 1 %32 Sony DualSense Controller Light Guide Replacement: passo 28, imagem 2 %32
    • Use a pair of tweezers or your fingers to remove the light guide bracket.
  29. Sony DualSense Controller Light Guide Replacement: passo 29, imagem 1 %32 Sony DualSense Controller Light Guide Replacement: passo 29, imagem 2 %32
    • Use a pair of tweezers or your fingers to remove the light guide.
Conclusão
Uma outra pessoa concluiu este guia.
Sam Omiotek
Membro desde: 02/25/19
92.806 Reputação
Autoria de 290 guias
2Comentários do guia
what do i need to do if player indicator white light doesn't work? please help i can't find any guide on the internet
Avt - Responder
I have the same problem. Did you find a fix?
Clayerhd -
Comentar
Visualizações:
Últimas 24 horas: 8
Últimos 7 dias: 45
Últimos 30 dias: 295
Ao todo: 7,882
