Ir para o conteúdo principal
Sony DualSense Controller L1 and R1 Button Replacement
O que você precisa
  1. Sony DualSense Controller L1 and R1 Button Replacement, Remove the L1 button: passo 1, imagem 1 %32 Sony DualSense Controller L1 and R1 Button Replacement, Remove the L1 button: passo 1, imagem 2 %32 Sony DualSense Controller L1 and R1 Button Replacement, Remove the L1 button: passo 1, imagem 3 %32
    • With one hand, grip the controller and use your thumb to hold down the left trigger.
    • With your free hand, insert the flat end of a spudger between the L1 and L2 buttons.
    • Use the spudger to gently pry the L1 button away from the controller and remove it, holding your finger over the button so it doesn't eject.
  2. Sony DualSense Controller L1 and R1 Button Replacement, Remove the R1 button: passo 2, imagem 1 %32 Sony DualSense Controller L1 and R1 Button Replacement, Remove the R1 button: passo 2, imagem 2 %32 Sony DualSense Controller L1 and R1 Button Replacement, Remove the R1 button: passo 2, imagem 3 %32
    • Repeat the previous step to remove the R1 button.
Conclusão
14 outras pessoas executaram este guia.
Sam Omiotek
Membro desde: 02/25/19
92.557 Reputação
Autoria de 290 guias
3Comentários do guia
It is easier to remove L1/R1 by going from below than by from above- without any damages.
Grim Of Doom - Responder
Does the spudger dent or mark the button when doing this?
Rory Bedell - Responder
My replacement R1 button is different enough to not fit. Fins around center sleeve are wider. So there must have been a design change at some point.
Walt Mather - Responder
Comentar
Visualizações:
Últimas 24 horas: 31
Últimos 7 dias: 334
Últimos 30 dias: 1,340
Ao todo: 43,108
