Introdução
Follow this guide to replace the buttons on a Sony PlayStation 5 DualSense controller.
Note: This guide is for DualSense controllers with an FCC ID ending in 1. Check the back of your controller to verify your model. If yours ends in A, there will be differences in the internal design.
O que você precisa
Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
Lift the middle trim over the joysticks to remove it.
With one hand, grip the controller and use your thumb to hold down the left trigger.
With your free hand, insert the flat end of a spudger between the L1 and L2 buttons.
Use the spudger to gently pry the L1 button away from the controller and remove it, holding your finger over the button so it doesn't eject.
Use a Phillips screwdriver to remove the two 6.4 mm screws securing the bottom corners of the lower case.
Use the point of a spudger to release the two clips on either side of the headset jack.
Ferramenta utilizada neste passo:Tweezers$4.99
Use a pair of tweezers or your fingers to disconnect the battery from the motherboard.
Grab the lower microphone ribbon cable pull tab with your fingers or a pair of tweezers and disconnect it from the motherboard.
Use a Phillips screwdriver to remove the 6.4 mm screw securing the battery bracket.
Grip the right trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers and pull up to disconnect it from the motherboard.
Grip the left trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers and pull up to disconnect it from the motherboard.
Use a pair of tweezers or your fingers to grip the upper microphone ribbon cable pull tab, and pull up to disconnect it from the motherboard.
Use a pair of tweezers or your fingers to grip the touchpad ribbon cable pull tab, and pull it straight out of the motherboard connector.
Carefully guide the joysticks through the front case and lift the motherboard out.
The motherboard is held down by two clips. One between the motherboard itself and the right trigger assembly, and one between the motherboard itself and the left trigger assembly. Gently push on either clip to release the motherboard from its restraints.
Use a Phillips screwdriver to remove the two 8.5 mm screws securing the light guide.
Use a pair of tweezers to remove the speaker from the midframe.
Use a Phillips screwdriver to remove the two 6.4 mm screws securing the midframe to the front case.
Use a pair of tweezers or your fingers to remove the three conductive silicone rubber pads from the inside of the front case.
Hold the front case close to the surface of your table and slowly turn the front case over to let the buttons fall out.
40 outras pessoas executaram este guia.
6Comentários do guia
good step by step list. easy to follow. thanks
You can skip step 25 and 26 as it is not necessary to remove them.
Thanks, you make me economizes 70€, my issue were the directional arrows up, I just followed the instructions clean everything, then test it, is work perfectly! I recommend! For every person read this comment, take your time, no need to force on anything Japanese people think perfectly about it!
