Ir para o conteúdo principal
Sony DVP-SR200P Processing Board Replacement
O que você precisa
  1. Sony DVP-SR200P Processing Board Replacement, Top Cover: passo 1, imagem 1 %32 Sony DVP-SR200P Processing Board Replacement, Top Cover: passo 1, imagem 2 %32
    • Remove the five #1 Phillips screws (black, 3/16") attaching the cover to the DVD player.
    • One 3/16" screw on the right side of the DVD player.
    • One 3/16" screw on the left side of the DVD player (directly opposite of other screw).
    • Three 3/16" screws on the back of the DVD player.
    Pergunte ao FixBot
    Comentar
  2. Sony DVP-SR200P Processing Board Replacement: passo 2, imagem 1 %32 Sony DVP-SR200P Processing Board Replacement: passo 2, imagem 2 %32
    • Slide the cover away from the front of the DVD player until it is off.
    Pergunte ao FixBot
    Comentar
  3. Sony DVP-SR200P Processing Board Replacement, Processing Board: passo 3, imagem 1 %32
    • Remove the blue tape from the processing board by gently pulling upward.
    Pergunte ao FixBot
    Comentar
  4. Sony DVP-SR200P Processing Board Replacement: passo 4, imagem 1 %32 Sony DVP-SR200P Processing Board Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use the tweezers to remove the four sets of wires connected to the processing board. Start with the cord located in front of the row of three cords.
    • The wires may be difficult to remove. Wiggling them while lifting them up may help remove them.
    Pergunte ao FixBot
    Comentar
  5. Sony DVP-SR200P Processing Board Replacement: passo 5, imagem 1 %32
    • Handle the processing board with care. It is fragile.
    • Unscrew the two #1 Phillips screws (silver, 3/16") located on the two edge corners of the processing board.
    Pergunte ao FixBot
    Comentar
  6. Sony DVP-SR200P Processing Board Replacement: passo 6, imagem 1 %32
    • Orient the DVD player so that you are facing the video and audio jacks.
    • Unscrew the two #1 Phillips screws (silver, 3/16") located on the outside of the DVD player
    • The processing board is now free to be removed and replaced.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Brian Hua
Membro desde: 01/11/13
80 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 5-17, Forte Winter 2013 Membro de Cal Poly, Team 5-17, Forte Winter 2013
CPSU-FORTE-W13S5G17
5 Membros
Autoria de 6 guias
3Comentários do guia
I have Sony DVD player dvp at510p. After switching it runs then automatic Power go down while running it's process ic get hotter and hotter what's the right solutions plz help me
Dhiraj Vasave - Responder Compartilhar
SO my DVD player run 5to 6 minutes then automatic stop all power goes to less
My DVD player not run but power on Bluetooth not connect
Sony - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 14
Últimos 30 dias: 59
Ao todo: 2,328
