Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Remove the five #1 Phillips screws (black, 3/16") attaching the cover to the DVD player.
One 3/16" screw on the right side of the DVD player.
One 3/16" screw on the left side of the DVD player (directly opposite of other screw).
Three 3/16" screws on the back of the DVD player.
Slide the cover away from the front of the DVD player until it is off.
Remove the blue tape from the processing board by gently pulling upward.
Use the tweezers to remove the four sets of wires connected to the processing board. Start with the cord located in front of the row of three cords.
Unscrew the two #1 Phillips screws (silver, 3/16") located on the two edge corners of the processing board.
Orient the DVD player so that you are facing the video and audio jacks.
Unscrew the two #1 Phillips screws (silver, 3/16") located on the outside of the DVD player
Unhook the power supply connector from the power supply board by pressing down on the small latch.
Orient the DVD player so the back of the DVD player is opposite of you.
Unscrew the two silver 4.8 mm Phillips #1 screws that attach the power supply circuit board to the bottom of the DVD player.
4 outras pessoas executaram este guia.
2 comentários
my sony home theater showing push power protector how to resolve it.
Service center said that we need to change motherboard. plz help me out if you can
