Ir para o conteúdo principal
Sony DSC-RX10M3 Back and Right Panel Replacement
O que você precisa
    1. Sony DSC-RX10M3 Back and Right Panel Replacement, Battery Replacement: passo 1, imagem 1 %32
      • Turn off the Device by scrolling the tab to "OFF" indicated by the arrow.
      Pergunte ao FixBot
      Comentar
    2. Sony DSC-RX10M3 Back and Right Panel Replacement: passo 2, imagem 1 %32 Sony DSC-RX10M3 Back and Right Panel Replacement: passo 2, imagem 2 %32 Sony DSC-RX10M3 Back and Right Panel Replacement: passo 2, imagem 3 %32
      • Remove the battery located at the bottom of the device.
      Pergunte ao FixBot
      Comentar
    1. Sony DSC-RX10M3 Back and Right Panel Replacement, Back and Right Panel: passo 3, imagem 1 %32
      • Remove the twelve 0.7mm Phillips #000 screws from the bottom case.
      Pergunte ao FixBot
      Comentar
    2. Sony DSC-RX10M3 Back and Right Panel Replacement: passo 4, imagem 1 %32 Sony DSC-RX10M3 Back and Right Panel Replacement: passo 4, imagem 2 %32
      • Remove the two 0.7mm screws that secure the right side of the camera.
      • Remove the two 0.7mm screws that secure the left side of the camera, near the Wi-Fi logo and charging port.
      Pergunte ao FixBot
      Comentar
    3. Sony DSC-RX10M3 Back and Right Panel Replacement: passo 5, imagem 1 %32 Sony DSC-RX10M3 Back and Right Panel Replacement: passo 5, imagem 2 %32
      • Gently pull off the plastic eye guard.
      Pergunte ao FixBot
      Comentar
    4. Sony DSC-RX10M3 Back and Right Panel Replacement: passo 6, imagem 1 %32 Sony DSC-RX10M3 Back and Right Panel Replacement: passo 6, imagem 2 %32
      • Use a Phillips #000 screwdriver to remove the four 0.4mm screws located under the rubber eye guard.
      • Use a plastic opening tool to detach the back panel of the camera.
      Pergunte ao FixBot
      Comentar
    5. Sony DSC-RX10M3 Back and Right Panel Replacement: passo 7, imagem 1 %32
      Ferramenta utilizada neste passo:
      • This is a tight spot; make sure you use minimal force when removing the cover.
      • Using tweezers, disconnect the ribbon cable connecting the LCD to the circuit board.
      Pergunte ao FixBot
      Comentar
    6. Sony DSC-RX10M3 Back and Right Panel Replacement: passo 8, imagem 1 %32
      • This step is only needed if you wish to remove the right side panel.
      • Use a plastic openeing tool to gently detach the right panel.
      Pergunte ao FixBot
      Comentar
Conclusão
3 outras pessoas executaram este guia.
Salman Hersi
Membro desde: 01/14/20
339 Reputação
Autoria de 2 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 19
Últimos 30 dias: 72
Ao todo: 1,947
