Ir para o conteúdo principal
Sony DSC-RX100MA Screen Replacement
O que você precisa
    1. Sony DSC-RX100MA Screen Replacement, Back Cover: passo 1, imagem 1 %32 Sony DSC-RX100MA Screen Replacement, Back Cover: passo 1, imagem 2 %32 Sony DSC-RX100MA Screen Replacement, Back Cover: passo 1, imagem 3 %32
      • Remove battery by sliding the tab to open the cover
      Pergunte ao FixBot
      Comentar
    2. Sony DSC-RX100MA Screen Replacement: passo 2, imagem 1 %32 Sony DSC-RX100MA Screen Replacement: passo 2, imagem 2 %32 Sony DSC-RX100MA Screen Replacement: passo 2, imagem 3 %32
      • Using the screwdriver, remove all screws (black 2.5mm) from outermost layer of the assembly.
      • All screws in the camera can be removed with the PH 0 driver head.
      Pergunte ao FixBot
      Comentar
    3. Sony DSC-RX100MA Screen Replacement: passo 3, imagem 1 %32 Sony DSC-RX100MA Screen Replacement: passo 3, imagem 2 %32 Sony DSC-RX100MA Screen Replacement: passo 3, imagem 3 %32
      • Also using the screwdriver, remove screws (black 1mm) underneath articulated LCD screen.
      • Remove the marked 2.5 mm screws with the screwdriver
      Pergunte ao FixBot
      Comentar
    4. Sony DSC-RX100MA Screen Replacement: passo 4, imagem 1 %32 Sony DSC-RX100MA Screen Replacement: passo 4, imagem 2 %32
      • Using the plastic opening tools, carefully pry off the bottom plate.
      • Do not pull too hard as you may break the plastic casing.
      Pergunte ao FixBot
      Comentar
    5. Sony DSC-RX100MA Screen Replacement: passo 5, imagem 1 %32 Sony DSC-RX100MA Screen Replacement: passo 5, imagem 2 %32 Sony DSC-RX100MA Screen Replacement: passo 5, imagem 3 %32
      • Using the same plastic opening tools, separate the screen and back assembly from the front portion of the camera
      • Once the back assembly is slightly detached, pull the media covers for the HDMI and Multimedia ports
      Pergunte ao FixBot
      Comentar
    6. Sony DSC-RX100MA Screen Replacement: passo 6, imagem 1 %32 Sony DSC-RX100MA Screen Replacement: passo 6, imagem 2 %32
      • Remove the back cover
      Pergunte ao FixBot
      Comentar
    1. Sony DSC-RX100MA Screen Replacement, Screen: passo 7, imagem 1 %32 Sony DSC-RX100MA Screen Replacement, Screen: passo 7, imagem 2 %32 Sony DSC-RX100MA Screen Replacement, Screen: passo 7, imagem 3 %32
      • Move side panel to get access to screws
      • Remove two screws (black 2.5mm) with PH #0 screwdriver
      Pergunte ao FixBot
      Comentar
    2. Sony DSC-RX100MA Screen Replacement: passo 8, imagem 1 %32 Sony DSC-RX100MA Screen Replacement: passo 8, imagem 2 %32
      • Remove back panel assembly while still keeping ribbon cable attached
      • Be very gentle and care not to tear the gold ribbon cable. This will be a common theme throughout these replacement guides.
      Pergunte ao FixBot
      Comentar
    3. Sony DSC-RX100MA Screen Replacement: passo 9, imagem 1 %32 Sony DSC-RX100MA Screen Replacement: passo 9, imagem 2 %32
      • Carefully unplug ribbon connector to fully detach LCD screen assembly from camera
      Pergunte ao FixBot
      Comentar
Conclusão
KC Egger
Membro desde: 02/10/17
315 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 21-1, Maness Winter 2017 Membro de Cal Poly, Team 21-1, Maness Winter 2017
CPSU-MANESS-W17S21G1
5 Membros
Autoria de 10 guias
5Comentários do guia
Any idea where I can get a set or replacement screws? one came out of my LCD joint and I can’t find replacements anywhere online. I’ve even tried Ebay.
Alberto Lora - Responder Compartilhar
Definately be careful with the gold ribbon cable, looked at mine funny and it just snapped in two.. waiting on a replacement now :(
Connor Quinn - Responder Compartilhar
I’ve ripped 2 of these before - not fun! Still… cheap enough to buy but delivery took a couple of weeks.
I had a cracked screen so had to take this out to replace as well - problem i’ve had is that although i stuck it down really well (with 3M 1mm double-sided tape, it doesn’t hold great and so the screen has risen a bit and doesn’t sit flush.
Just in the process now of sticking it down again but with a touch of superglue as i need it to hold down a bit better - that should hopefully be me done then :)
Great guide by the way KC Egger - thanks for taking the time to put this together - it’s been a life saver for me!
Jamie Dunkley - Responder Compartilhar
Where did you purchase your screen, I’ve been trying to find one from Sony parts dealers and can’t find it. Any links would be helpful, thanks.
Ian Cullen - Responder Compartilhar
Probably a late reply but I got my screen from AliExpress, there are still a lot of them for sale and the sellers include a ribbon cable with the screen.
For these cameras the official screen protector is Sony PCK-LM15 Screen Protector
I think mine was damaged by sunscreen on my hands when using the camera over summer so putting a protective layer on top should help preserve the new screen.
Andrew Fox - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 26
Últimos 30 dias: 119
Ao todo: 7,041
