Ir para o conteúdo principal
Sony Cyber-shot DSC-P9 Flash Replacement
O que você precisa
    1. Sony Cyber-shot DSC-P9 Flash Replacement, Battery: passo 1, imagem 1 %32
      • Slide the battery latch down the side of the camera with your hands.
      • The latch will automatically pop open.
      Pergunte ao FixBot
      Comentar
    2. Sony Cyber-shot DSC-P9 Flash Replacement: passo 2, imagem 1 %32
      • Unlatch the clip over the battery.
      • The battery will partially pop out.
      Pergunte ao FixBot
      Comentar
    3. Sony Cyber-shot DSC-P9 Flash Replacement: passo 3, imagem 1 %32 Sony Cyber-shot DSC-P9 Flash Replacement: passo 3, imagem 2 %32
      • Remove the battery from the camera.
      Pergunte ao FixBot
      Comentar
    1. Sony Cyber-shot DSC-P9 Flash Replacement, Outer Casing: passo 4, imagem 1 %32 Sony Cyber-shot DSC-P9 Flash Replacement, Outer Casing: passo 4, imagem 2 %32
      • Remove the four 3.0mm Phillips #000 screws on the top of the camera with the phillips screwdriver.
      • Remove the additional four 3.0mm Phillips #000 screws on the bottom of the camera.
      Pergunte ao FixBot
      Comentar
    2. Sony Cyber-shot DSC-P9 Flash Replacement: passo 5, imagem 1 %32 Sony Cyber-shot DSC-P9 Flash Replacement: passo 5, imagem 2 %32
      • Once the screws are removed, slowly remove the back casing from the rest of the camera.
      Pergunte ao FixBot
      Comentar
    3. Sony Cyber-shot DSC-P9 Flash Replacement: passo 6, imagem 1 %32 Sony Cyber-shot DSC-P9 Flash Replacement: passo 6, imagem 2 %32
      • Then, pull the front case away from the rest of the camera.
      Pergunte ao FixBot
      Comentar
    4. Sony Cyber-shot DSC-P9 Flash Replacement: passo 7, imagem 1 %32
      • After the casing is removed, the camera should look as shown.
      Pergunte ao FixBot
      Comentar
    1. Sony Cyber-shot DSC-P9 Flash Replacement, Lens: passo 8, imagem 1 %32 Sony Cyber-shot DSC-P9 Flash Replacement, Lens: passo 8, imagem 2 %32
      • Dislodge the round casing from the lens.
      • Pull it away from the rest of the camera.
      Pergunte ao FixBot
      Comentar
    2. Sony Cyber-shot DSC-P9 Flash Replacement: passo 9, imagem 1 %32
      • Unscrew the two 4.0mm Phillips #000 screws from the display.
      Pergunte ao FixBot
      Comentar
    3. Sony Cyber-shot DSC-P9 Flash Replacement: passo 10, imagem 1 %32
      • Pull the two ribbon cables out of their slots on the back circuit board.
      Pergunte ao FixBot
      Comentar
    4. Sony Cyber-shot DSC-P9 Flash Replacement: passo 11, imagem 1 %32
      • Remove the three 4.0mm Phillips #000 screws holding the back panel in place.
      Pergunte ao FixBot
      Comentar
    5. Sony Cyber-shot DSC-P9 Flash Replacement: passo 12, imagem 1 %32 Sony Cyber-shot DSC-P9 Flash Replacement: passo 12, imagem 2 %32 Sony Cyber-shot DSC-P9 Flash Replacement: passo 12, imagem 3 %32
      • Work the back panel out from under the small grey clip.
      • Slide the back panel off of the camera by dislodging it from the remaining clips.
      • Below is a flat, orange cable connecting the lens to the motherboard.
      • Be careful not to bend the back plate during this process.
      Pergunte ao FixBot
      Comentar
    6. Sony Cyber-shot DSC-P9 Flash Replacement: passo 13, imagem 1 %32
      • Turn the camera over so that you can see the front of the lens.
      • Two connectors link the lens to the motherboard.
      • Gently bring the lens away from the camera.
      Pergunte ao FixBot
      Comentar
    7. Sony Cyber-shot DSC-P9 Flash Replacement: passo 14, imagem 1 %32
      • Using the flat end of the plastic spudger tool, flip up the black tabs on the connectors.
      • Be careful not to exert too much force, as the connectors are delicate.
      Pergunte ao FixBot
      Comentar
    8. Sony Cyber-shot DSC-P9 Flash Replacement: passo 15, imagem 1 %32 Sony Cyber-shot DSC-P9 Flash Replacement: passo 15, imagem 2 %32 Sony Cyber-shot DSC-P9 Flash Replacement: passo 15, imagem 3 %32
      • Gently pull out the cables and move the lens away from the rest of the camera.
      • You should now have two distinct, separate components.
      Pergunte ao FixBot
      Comentar
    1. Sony Cyber-shot DSC-P9 Flash Replacement, Flash: passo 16, imagem 1 %32
      • Remove the 3.0mm Phillips #000 screw at the top of the battery door.
      Pergunte ao FixBot
      Comentar
    2. Sony Cyber-shot DSC-P9 Flash Replacement: passo 17, imagem 1 %32 Sony Cyber-shot DSC-P9 Flash Replacement: passo 17, imagem 2 %32
      • Pull off the top button piece. You will have to detach a small blue ribbon cable.
      Pergunte ao FixBot
      Comentar
    3. Sony Cyber-shot DSC-P9 Flash Replacement: passo 18, imagem 1 %32 Sony Cyber-shot DSC-P9 Flash Replacement: passo 18, imagem 2 %32
      • Caution: the capacitor, a black cylinder near the top of the camera, might have a charge in it, which could be harmful to you or the camera. Neutralize it by touching both wires with a screwdriver at the same time.
      Pergunte ao FixBot
      Comentar
    4. Sony Cyber-shot DSC-P9 Flash Replacement: passo 19, imagem 1 %32 Sony Cyber-shot DSC-P9 Flash Replacement: passo 19, imagem 2 %32 Sony Cyber-shot DSC-P9 Flash Replacement: passo 19, imagem 3 %32
      • Remove the flash mechanism. It is held in place by a clip on the side of the camera.
      • The capacitor and flash will rotate out, still attached by a ribbon cable on the left.
      Pergunte ao FixBot
      Comentar
    5. Sony Cyber-shot DSC-P9 Flash Replacement: passo 20, imagem 1 %32 Sony Cyber-shot DSC-P9 Flash Replacement: passo 20, imagem 2 %32
      • Lift up the black tab with the spudger.
      • Gently remove the ribbon cable from the rest of the camera.
      • The flash component is now completely separate from the rest of the camera.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
Cal Poly, Team 17-25, Amido Spring 2012 Membro de Cal Poly, Team 17-25, Amido Spring 2012
CPSU-AMIDO-S12S17G25
4 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 19
Ao todo: 1,075
