Ir para o conteúdo principal
Sony Cyber-shot DSC-H300 Screen Replacement
O que você precisa
  1. Sony Cyber-shot DSC-H300 Screen Replacement, Removing screws: passo 1, imagem 1 %32 Sony Cyber-shot DSC-H300 Screen Replacement, Removing screws: passo 1, imagem 2 %32
    • Remove the four 6mm Phillips #00 screws.
  2. Sony Cyber-shot DSC-H300 Screen Replacement, Removing screws: passo 2, imagem 1 %32 Sony Cyber-shot DSC-H300 Screen Replacement, Removing screws: passo 2, imagem 2 %32
    • Remove the two 6mm Phillips #00 screws.
    • Remove the two 3mm Phillips #00 screws.
  3. Sony Cyber-shot DSC-H300 Screen Replacement: passo 3, imagem 1 %32 Sony Cyber-shot DSC-H300 Screen Replacement: passo 3, imagem 2 %32 Sony Cyber-shot DSC-H300 Screen Replacement: passo 3, imagem 3 %32
    • Use the flat end of a plastic spudger to pry apart the rear cover from the body of the camera.
    • Be careful not to damage the three plastic clips securing the top edge of the rear cover.
  4. Sony Cyber-shot DSC-H300 Screen Replacement, Screen: passo 4, imagem 1 %32
    • Remove the two 6 mm Phillips #00 screws securing the left side of the metal frame.
    • Gently pull the metal frame away from the screen.
    • Lift the screen with the spudger and flip it to the right.
  5. Sony Cyber-shot DSC-H300 Screen Replacement: passo 5, imagem 1 %32
    • Remove the four 6mm Phillips #00 black screws.
    • Lift the metal plate away from the board.
  6. Sony Cyber-shot DSC-H300 Screen Replacement: passo 6, imagem 1 %32
    • Disconnect the LCD cable.
Conclusão
3 outras pessoas executaram este guia.
Zachary Meyer
Membro desde: 02/14/18
479 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S1-G6, Nance Spring 2018 Membro de USF Tampa, Team S1-G6, Nance Spring 2018
USFT-NANCE-S18S1G6
3 Membros
Autoria de 10 guias
Um comentário
where can i find the rear screen for sony dsc-h300
Michael Ramos - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 17
Últimos 30 dias: 53
Ao todo: 2,185
