Ir para o conteúdo principal
Sony Cyber-shot DSC-H20 Capacitor Assembly Replacement
O que você precisa
  1. Sony Cyber-shot DSC-H20 Capacitor Assembly Replacement, Capacitor Assembly: passo 1, imagem 1 %32 Sony Cyber-shot DSC-H20 Capacitor Assembly Replacement, Capacitor Assembly: passo 1, imagem 2 %32
    • Slide open the cover and remove the battery and the Memory Stick Duo.
    • Return the battery cover to its closed position.
  2. Sony Cyber-shot DSC-H20 Capacitor Assembly Replacement: passo 2, imagem 1 %32
    • Remove all three screws from the bottom of the camera.
  3. Sony Cyber-shot DSC-H20 Capacitor Assembly Replacement: passo 3, imagem 1 %32 Sony Cyber-shot DSC-H20 Capacitor Assembly Replacement: passo 3, imagem 2 %32
    • Remove the screws on the left and right sides of the camera.
  4. Sony Cyber-shot DSC-H20 Capacitor Assembly Replacement: passo 4, imagem 1 %32 Sony Cyber-shot DSC-H20 Capacitor Assembly Replacement: passo 4, imagem 2 %32
    • Place the camera upside down with the battery port positioned upward.
    • Slide open the battery port.
  5. Sony Cyber-shot DSC-H20 Capacitor Assembly Replacement: passo 5, imagem 1 %32 Sony Cyber-shot DSC-H20 Capacitor Assembly Replacement: passo 5, imagem 2 %32 Sony Cyber-shot DSC-H20 Capacitor Assembly Replacement: passo 5, imagem 3 %32
    • Pry the front cover of the camera off with the plastic opening tool.
  6. Sony Cyber-shot DSC-H20 Capacitor Assembly Replacement: passo 6, imagem 1 %32
    • Remove the power shutter unit.
    • Caution: Touching the capacitor wires may cause serious injury. Use a capacitor discharge probe to safely rid the capacitors of dangerous charges.
Conclusão
Uma outra pessoa concluiu este guia.
Reuben Martinez
Membro desde: 02/23/15
333 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 1-1, Leahy Winter 2015 Membro de USF Tampa, Team 1-1, Leahy Winter 2015
USFT-LEAHY-W15S1G1
Membros da 3
Autoria de 10 guias
4 comentários
my camera wont turn on i have made shure that my battery is properly put inside and my battery is not dead because i have checked my battery on another camera the lens is stuck and the camera automaticaly turned off saying error now it wont turn on
i have a sony cybershot dsc-h20
please help me
parth patel - Responder
@parth patel
dear patel, I am having same model camera and facing same trouble as you mentioned in your message. I hope you fixed your camera. Please share with me your experience to resolve your camera problem. thanks.
Sivakumar -
some of salty water drops on beach fell on my camera sony dsc-h20 so the camera is not at all starting please can you tell me what problem the camera has ?? and how it will be repaired ?? and please tel me the price ?????
srushti vernekar - Responder
Please help me, My camera’s selection mode is changes automatically and frequently
Sushil Nagar - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 12
Últimos 30 dias: 21
Duração total: 1,515
